Harmonic balancer
Old Jan 21, 2012 | 10:57 AM
mustang81's Avatar
mustang81
Harmonic balancer
What is the torque for the harmonic balancer on 351m/400. I have a 351m and a convert to 400 by changing the crank and piston. I need some # for the torque it will be grately appreciate. I have the Monero book but i can't find it.thank in advance.
Old Jan 22, 2012 | 11:35 AM
mark a.'s Avatar
mark a.
80 ft.lbs.
Old Jan 22, 2012 | 12:45 PM
mustang81's Avatar
mustang81
thank you, it's all done. Now i can put oil in it. Before start up i need to prime the oil system. I read some where i can prime with a drill. I don't have the special tool but if i remove the distributer how can i done that ?
First engine rebuilt with aussie head and tim piston 9.5:1 0.030 over, straight up timing chain, permormer 400 edelbrock intake, 600cfm edelbrock carb, roller rocker, custom push-rods, extrem energy cam, lifter, rebuilt head with new valve(stainles) 3 angles valve job with new valve guide on exhaust side, spring to match the cam, rebuild 400 crank 0.010 under, new oil pump, water pump, complete gasket set. Missing bolt on intake hole for vaccum i guess, oil pressure sending unit, spark plug and wire. Gonna bring to the dyno shop for break-up and know the torque and hp.
Old Jan 22, 2012 | 03:51 PM
POPAJON's Avatar
POPAJON
mustang81........... you and I have talked before. We have roughly the same build. If you have an unused/ dummied distributor you can make the tool you need. I believe if you gut the top of the distributor and use the distributor shaft and pump rod you'll be able to prime the engine. OR the dyno shop will do it for you. Let us know the numbers you get. Popa John
Old Jan 22, 2012 | 04:37 PM
crsmiffy's Avatar
crsmiffy
I used a socket set with extension that fitted the hex oil pump-dizzy drive but also went down the hole so a slim 3/8 one is the go. I also had an adapter made up from a piece of 3/8 square steel (any machine/engineering shop will have 3/8 key steel cheap) with a triangle quickly ground into it to transmit the drive from the drill to the socket extension. One trick though use some insulation tape to fix the socket to the extension so it doesnt fall off. Remember to drive the drill backwards and dont blow it up, if it starts to smell give it a rest for a while LOL. Go until oil comes out everywhere rockers etc. That engine package should go really well.
Old Jan 26, 2012 | 06:36 PM
mustang81's Avatar
mustang81
Originally Posted by POPAJON
mustang81........... If you have an unused/ dummied distributor you can make the tool you need. I believe if you gut the top of the distributor and use the distributor shaft and pump rod you'll be able to prime the engine. OR the dyno shop will do it for you. Let us know the numbers you get. Popa John
Yes i have one more distributor i'm not going to use, so i'm gonna take the time to look at that, never think about that. Maybe use extention and 3/8.
Thanks all for replying, i appreciate.
mustang81
May 22, 2010 12:16 AM
smokeyb97
May 28, 2009 05:03 PM
5.0stang
Oct 26, 2007 09:14 AM
truckman79
16
Apr 24, 2005 07:56 PM
truckman79
Feb 9, 2004 08:44 PM
