Where is it Leaking from??
Two 13mm bolts on the bottom of the fuel bowl, two fuel lines from bowl to pump, one rubber line at the FPR return, two high pressure line at the FPR witch is 11/16", unplug the wire on the pass. side of fuel bowl and unplug the IPR the the bowl comes out
You make it sound easy like you have done it a few times? lol
Man what a pain
Heres some info
Welcome to guzzle's Powerstroke Fuel Bowl Rebuild Web Page
Not the same model but its simular
Heres some info
You must be a pro by now...lol...How long did it take you? Well what did you find each time? same problems or different each time.
Use a 7/8's bent wrench to remove the stand pipe. The pipe is reverse threads. Be sure to not grab it by the top or it will break off.
Turning it clockwise with the wrench remove the stand pipe and then the heater pedistal and heater element.
Then wipe the bowl out good and look for places where there could be a hole in the bowl. If it has a hole we have patched the inside of the bowl effectively with a polymer epoxy. Cleaning with brake cleaner first and then patching. If no hole then you can continue removing it like Mike mentions.
lol.. Thanks.. Just want to get it on the road... I gotta deal with my steering issue next.. My steering wheel must have had a bearing go bad in it. It moves up and down.. way to much play.. drives fine but I dont like the play.
I would drain the fuel bowl
Then wipe the bowl out good and look for places where there could be a hole in the bowl. If it has a hole we have patched the inside of the bowl effectively with a polymer epoxy. Cleaning with break cleaner first and then patching. If no hole then you can continue removing it like Mike mentions.
OK well thanks for the suggestions guys.. I am gonna try and tackle this tomorrow afternoon if we dont get much rain here.. So tired of driving my IDI when I got a PSD in the driveway!
