no turbo spool
Old Jan 20, 2012 | 09:07 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan
Originally Posted by Iallwork
this may sound stupid, but here goes, check your air cleaner, get some diesel clean (POWER SERVICES)and dump it in your fuel canister (when the truck is warmed up) then run it to clean your injectors. On mine I could sure here the turbo after that (for some reason). If your ebpv is closed i don't think it would have any power, but maybe that's it.
Thats not stupid, I was thinking the same thing! The EBPV wont cause the whitesmoke though.
Old Jan 20, 2012 | 09:44 PM
Talyn's Avatar
Talyn
Actually, if he has a catalytic converter, its probably plugged.
Old Jan 20, 2012 | 09:45 PM
Talyn's Avatar
Talyn
It will usually cause greyish smoke.
He really should check the turbo to make sure its not burnt up.
It should freely spin while inspecting it.
Old Jan 20, 2012 | 10:05 PM
matowns21's Avatar
matowns21
I will check it tomorrow in the morning... So the only sign is free motion or no motion?
Old Jan 20, 2012 | 10:36 PM
Talyn's Avatar
Talyn
Take the intake boot off and reach your hand inside.
Grab ahold of the end and see how much it wiggles.
It should move just slightly.
not much.
Then take it and try and spin it like you'd do a pinwheel.
It should freely spin easily and keep spinning.
if the turbo checks out and you have a catalytic converter, I bet your cat is plugged.
All leather
General Diesel Discussion
Feb 28, 2014 06:53 AM
quesey
May 19, 2013 06:21 PM
Jay94250
Sep 1, 2010 05:21 PM
dylan8427
Sep 14, 2009 11:36 PM
IronHeaDCanada
Mar 31, 2008 06:06 PM
