Blue smoke
Old Mar 24, 2007 | 10:55 PM
IronHeaDCanada's Avatar
IronHeaDCanada
Blue smoke
Help a diesel noob out.....
I bought a 2002 Ford F350 7.3 powerstroke in the fall. All winter it blew blue smoke, especially while it was cold. When it warmed up, it was a little bit better. I just thought it was because of the cold weather and such.
Anyways, it just got nice here in Alberta, Canada, and it is still smoking blue. It blows the blues at idle and puffs it out when I first take off. When I have the pedal down and revs are around 3000, the smoking stops, however returns at idle.
I took it in to a stealership in Jan. and they told me my blowback or blowby was high and I needed a new engine.
Could the cause of the blue smoke be the blowback or could it be injectors or injector pump? Or maybe its something else altogether.
Oh ya....I just changed my air filter from a filthy K&N to the KWIK filter system....thumbs up so far!!
Any help would be appreciated...thanks.
Old Mar 25, 2007 | 12:40 AM
jtharvey's Avatar
jtharvey
To me, it sounds like the turbo is going bad, like the ring seals on the turbo are going out or gone - particularly the exhaust side. My turbo went and it had the same symptoms - puff at idle and when I first took off.
There were no other sympotms that the turbo was going bad, no noises and it made normal boost. But, when I checked endplay on the turbo shaft, there was way too much.
Check your turbo shaft end play first, you could be doing damage that will require a whole new turbo if there's too much play and the turbo wheels are hitting the housing.
Old Mar 25, 2007 | 12:49 AM
Tenn01PSD350's Avatar
Tenn01PSD350
How did they diagnose that? Check yourself by pulling the oil filler cap off and start it up. If it puffs like a steam locomotive they were on to something. A real quick check. Also, when checking the turbo, just pull the intake tube off of the housing and grasp the nut on the impellar. Try moving in and out and up and down. Should be almost imperceptable play either way. Do not touch the fins, but inspect them for dusting. Good luck
Old Mar 25, 2007 | 12:51 AM
rollerstud98's Avatar
rollerstud98
what happens if you touch the fins? oil from skin deteriorate them?
Old Mar 25, 2007 | 01:01 AM
Tenn01PSD350
LOL, you would think so the way I posted that. Actually it is more critical on the turbine than the impellar due to soot but there may be dust on the impellar and yes, removing that dust and or adding oil from the skin may upset a balance that is critical at the 10s of Ks the turbo spins. Your mileage may vary. It may do nothing, and the turbo may head south.
Old Mar 25, 2007 | 11:07 AM
IronHeaDCanada
Thanks for all the suggestions guys!
I'm not sure how the stealership diagnosed the blowback, but they insisted I spend $14K on a new engine. I told them I'd do some more checking myself first!!
I'm gonna check the turbo...sounds exactly like your symptoms jtharvey.
Old Mar 30, 2008 | 08:24 PM
BlackJeep's Avatar
BlackJeep
I don't mean to hijack the thread, but (Mike) my 2000 7.3 PSD puffs out of the oil filler when idling. Does this indicate a serious problem?
Thanks
John
Old Mar 30, 2008 | 09:48 PM
Tenn01PSD350
Thanks
John
Wow, dredged this one up. Is it just a light steady puff or a serious choo choo high pressure one? The filler will expell crankcase vapor but it should not be too pronounced. Hard to describe. You could find someone else with a 7.3 and compare.
Old Mar 30, 2008 | 10:07 PM
DISLFVR's Avatar
DISLFVR
Locomotive breath
A light steady stream like Mike said is ok, if it pulsates then you may have a problem. Kwik had a video clip of a vehicle with bad blow-by.
Old Mar 31, 2008 | 06:06 PM
BlackJeep's Avatar
BlackJeep
I saw the video online, NOTHING like that! Just a white mist blowing up "gently" while idling.
Thanks,
John
85Supclub
May 6, 2015 06:00 AM
jr_vw2
Jul 9, 2012 04:45 PM
H2recovery
Jan 4, 2012 01:17 PM
jonedoe
May 21, 2010 12:56 PM
bigdoffroad
23
Jan 2, 2010 10:14 AM
