Diff. gear oil?
Old Jan 20, 2012 | 02:55 PM
Sark's Avatar
Sark
Question Diff. gear oil?
What weight is everyone using?
I'm getting ready to install the "Mag-Hytec" diff. cover & they say 75w-140 weight. My Ford book shows 75w-90 for the F350/450 Dana 80.
I'm going to go with the Mobil 1 Synthetic.
We RV a lot, towing trk & trailer gross weight at 21,000+lb.
Last edited by Sark; Jan 20, 2012 at 03:00 PM. Reason: Found the answer finally in a passed thread
Old Jan 20, 2012 | 03:01 PM
Sark's Avatar
Sark
Finally found the passed thread on the subject. The majority are going with the 75w-140.
THanks
Old Jan 20, 2012 | 05:07 PM
npccpartsman's Avatar
npccpartsman
I would use the manufacturer's recommended oil weight. The cover doesn't matter.
Old Jan 20, 2012 | 08:31 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Don't forget the additive If You Have Limited slip!
Old Jan 20, 2012 | 08:53 PM
tonefordays's Avatar
tonefordays
Just changed the oil on my Sterling 10.5 two weeks ago, used Mobile 1 75w-140LS. Since the oil already has friction modifier in it, I didn't add any more to the mix, so far I have not noticed any binding, shutter, chirping etc on tight turns. I believe the Dana 80 uses the 75-90 as mentioned earlier.
Old Jan 20, 2012 | 09:14 PM
Sark's Avatar
Sark
Thumbs up
I agree that is said 75w-90. I've asked around & ck'd on this site & everyone recommends the 75w-140 do to the amount of heavy towing plus living in the San Diego area & not getting into the cold weather states. If it's that cold we don't go there.
Crewcabber
Oct 18, 2014 06:46 PM
ij72
Apr 10, 2014 06:02 AM
IDIDieselJohn
Jun 12, 2010 05:58 AM
desert sled
Apr 1, 2009 08:52 PM
mstephan
Aug 10, 2004 12:22 PM
