Front Differential
Old Apr 1, 2009 | 08:31 PM
desert sled's Avatar
desert sled
Front Differential
What weight oil do you use in the front differential on a 94 F-350? Do I need to use a friction modifier and how much. I am changing all the fluids and am not sure about the weight. Thanks for a great forum.
Old Apr 1, 2009 | 08:52 PM
RCrawler's Avatar
RCrawler
85W-140, 80W-90, 75w-140, etc. Pretty much any differential gear oil will work for you.
There was no factory LS option for the front axle. Unless someone has added one, it should be a standard open. So no additive should be needed. You can find out for sure once you remove the cover.
Jason
