Long Bed Dimensions
Old Jan 20, 2012 | 02:38 PM
Reziac's Avatar
Reziac
Long Bed Dimensions
Here I am still trying to buy a new-used truck, and I've run into a peculiar problem -- people who can't use a tape measure to save their lives! Anyway what I need to know, are all the 1994-95-96-97 (before the style change) F250/F350 beds the same dimensions, and how do they differ from my '78 F-100? (Haven't found any sample trucks locally that I can waylay and measure... and the purchase prospects are all over 300 miles away. Not handy!)
I need to everyday-haul stuff that fits fairly tight in my old bed, so this is important to me.
For reference, I'll append a Handy Diagram from my truck, complete with dents. (well, if it'll let me... I don't see any way to attach an image on this form. Do I need N-many posts first or something?)
a: 65.0" -- width inside the bedrail
b: 69.5" -- widest point inside the bed
c: 49.5" -- between wheel wells at floor level
d: 97.0" -- inside length without bedrail
e: 98.0" -- inside length including bedrail
bed depth 19"
Thanks!
Last edited by Reziac; Jan 20, 2012 at 02:39 PM. Reason: remember that trucks are three-dimensional! :D
Old Jan 20, 2012 | 03:26 PM
hivoltj's Avatar
hivoltj
bed depth 19"
Thanks!
As far as I know they are the same dimensions, other than the shape of the fender wells. I do believe Tonneau covers and such will fit 78-96 trucks no problem
Old Jan 20, 2012 | 03:41 PM
Reziac's Avatar
Reziac
That's what I thought, but... Someone I called re a 1997 F-250HD for sale went forth and measured and came up with only 64" wide, and I'm goin' whoa, that ain't gonna work for me, and WTF?!
Old Jan 20, 2012 | 03:49 PM
nvrsatisfied84's Avatar
nvrsatisfied84
im pretty sure they are very close to same i know i took the bedliner outta my 95 and it dropped right in to the 79 bed like it was made for it if that helps
Old Jan 20, 2012 | 04:45 PM
hivoltj's Avatar
hivoltj
I'll try to measure my '92 longbed tomorrow if it's not still below freezing a$$ outside.
Old Jan 20, 2012 | 10:24 PM
Reziac's Avatar
Reziac
Will be interesting to compare -- I've noticed variations in the width of the bedrail too.
Old Jan 23, 2012 | 02:13 PM
hivoltj's Avatar
hivoltj
Sorry bud, I forgot this weekend, and took the measurements before I re-read the post. I'll try to measure the others this afternoon.
Here's what I have on my '92 F-150 long bed
a : 65" width inside bedrail
b : 70.5" widest point in bed
c : 51.5" between wheel wells at floor level
d : 96.5" inside length without bedrail
e : 98" inside length with bedrail
I'll try to get the widest inside measurement later, I did measure narrowest though, its behind the wheel well, where the "hump" for the rear tank filler neck is. - 66"
To the bottom lip of the bedrail from the floor is 18", if you measured 19" at the top of the bedrail, that is probably the same.
Old Jan 23, 2012 | 03:55 PM
Diesel_Brad's Avatar
Diesel_Brad
They are the SAME EXACT bed structure with different sides. They use the same bed liner, tonno cover and cap
Old Jan 23, 2012 | 03:56 PM
Reziac's Avatar
Reziac
So at least the 1992 is pretty close to the '78! that's good to know. Thanks!
(Personally I think changing bed dimensions is one of the most boneheaded things a truck manufacturer can do!!)
Old Jan 23, 2012 | 04:00 PM
Diesel_Brad
Not ford. they kept the same bed dimensions for 24 years
Old Jan 23, 2012 | 04:07 PM
Reziac's Avatar
Reziac
Among the reasons I'm stickin' with these older Fords, you betcha
Old Jan 23, 2012 | 04:12 PM
hivoltj's Avatar
hivoltj
I edited my post and added the widest measurement, it's a little above the floor, there is an indentation in the bedside.
I would bet they are the exact same, our measurements are probably just a little different from two different people doing the measuring. I didn't have anybody to hold the other end of the tape, so mine are probably a little less accurate.
Old Jan 23, 2012 | 04:25 PM
Reziac's Avatar
Reziac
Yeah, I had to use the hook it to something and swear when it falls off method of measuring myself, so being half an inch one way or the other is probably just our collective bad aim Now I'm thinkin' the folks I mentioned who measured theirs at 64" mighta forgot to include the tape-measure body.
Benny996
Dec 17, 2023 12:51 PM
shoveex
Feb 24, 2010 08:54 PM
Fordtruck51
Jun 1, 2009 10:58 AM
jeff5683
Apr 25, 2006 11:11 AM
jeff5683
Mar 7, 2006 01:29 PM
