alternator
Old Jan 20, 2012 | 12:06 PM
deljac's Avatar
deljac
alternator
im having some problems with my alt ive had it tested and ive tried a new one and no change. i also have tried 3 different batteries and no change. when running my lights, my garmin, and radio at nite when im driving its charging about 14, when im at a light it drops to around 6, and as soon as i start going it jumps back up. i have tried changing the cable ends and same thing. i dont have underdrive pulleys. so im just at a loss
Old Jan 20, 2012 | 12:45 PM
Hotshot869's Avatar
Hotshot869
When your at a light and it drops voltage, then picks right back up when you start driving again, that tells me that your drawing power.. For your radio, is it a stock radio or do you have the whole setup with subwoofers and what not. The GPS shouldn't be affecting the voltage too much. My F250 did the same thing, I bought a new battery with higher CCA, voltage. It overall was bigger, but never had that problem again. For your radio, if it is the whole setup with the subwoofers, go with a capacitor.
Old Jan 20, 2012 | 01:32 PM
danr1's Avatar
danr1
Check the belt and or belt tensioner, sounds like its slipping.
Old Jan 20, 2012 | 02:49 PM
deljac's Avatar
deljac
its just a pioneer cd player with factory speakers, i have a 800cca battery. and i just checked the belt and its not slipping
jjkennedy98
2004 - 2008 F150
May 9, 2015 08:34 AM
quincyj34
May 19, 2014 03:13 PM
mikren
1997 - 2003 F150
Aug 10, 2011 08:44 PM
Inksma
Dec 14, 2006 04:18 PM
agelder
Electrical Systems/Wiring
Jan 16, 2004 03:17 PM
