Sponsored by: Auxito
intermitent battery light
Old Aug 7, 2011 | 04:15 PM
mikren's Avatar
mikren
hey guys, my wife has been using the truck the last 2 days and said the battery light in dash has come on a few times then has gone out...also mentioned the radio display went out also...then back on ,is the a sign the alternator is dying ?
She said the truck still ran fine when the battery light came on....the battery light was not on for long. It did it a few times.
I checked the voltage on the batt while the truck is both running and not and it's good
Old Aug 7, 2011 | 05:10 PM
Dave G.'s Avatar
Dave G.
Most likely cause is a failing alternator. The Amp gauge should also show a steady drop the longer you drive, or with a lot of things turned on, like lights, radio, wipers, etc..
Somewhat possible that the serpentine belt is slipping and not allowing the alternator to maintain constant speed. Should also check the battery cable connections to make sure that it can even take a charge.
Dave
Old Aug 7, 2011 | 09:38 PM
Bluegrass 7's Avatar
Bluegrass 7
If the Alternator is old it may be on the edge for brush wear.
Check the Alternator plug for being seated.
Battery cables etc
You won't see any voltage problem when measuring if the charge lamp is not on.
Normally if the Alternator stops charging the battery will still run everything until it's charge runs to low for some items such as the radio especially at night with the lights on.
With a single belt driving everything it seldom is the problem or you would have power steering and A/C issues with it and hear noises.
Good luck.
Old Aug 8, 2011 | 06:46 AM
mikren's Avatar
mikren
yeah I am suspecting the alternator also, it is old, but is there not a way to test and see if it is infact the problem ? like disconnecting the positive off the batt while the truck is running ?
Old Aug 8, 2011 | 10:42 AM
Bluegrass 7
No no, don't do that on modern computer controled systems.
Take it to a store or shop to test on equipment.
Old Aug 10, 2011 | 12:05 PM
mikren's Avatar
mikren
ok, fired up the truck last night and batt light was on. I did a load test it defenitly is the alt. My question is.... 95 or 130 amp. I don't know which one I have at the moment, no markings on it. It's a 5.4L XLT, power doors,locks andwindows,a/c...no power seats or anyting else. Will a 95amp do the job as I can get one pretty cheap. Thanks again guys
Old Aug 10, 2011 | 01:10 PM
Bluegrass 7
Here are considerations for chooseing one or the other.
1. The power options you have such as A/C.
2. Winter temps you encounter.
3. Cold weather cranking and battery recharge time.
I would opt for the larger and the biggest battery capacity you can get for your worst case conditions even though it's summer now it will serve you well in winter.
Good luck.
Old Aug 10, 2011 | 01:39 PM
mikren's Avatar
mikren
nuff said...I will opt for the bigger one....thanks again
Old Aug 10, 2011 | 08:44 PM
mikren's Avatar
mikren
swapped out the alt. today and all is well.
cr250
1997 - 2003 F150
Mar 26, 2019 10:00 AM
Steck804
1997 - 2003 F150
May 27, 2014 10:07 AM
Youngm
1997 - 2003 F150
Aug 22, 2012 04:00 PM
Bryan da Preacherman
Aug 12, 2011 01:29 PM
skin052
1997 - 2003 F150
15
Aug 7, 2009 05:29 PM
