Recurring Problems
Old Jan 23, 2012 | 07:14 PM
tje2015's Avatar
tje2015
when you jump it from the starter solenoid will it start?
Old Jan 23, 2012 | 07:57 PM
198769ford's Avatar
198769ford
nope, my starter winds but its not shooting to the flywheel to crank over, i was tapping it with a hammer today assuming it was frozen up but that still didn't work. but i did find that the little red wire that connects to the small terminal on the solenoid was cut to short to begin with, so the previous owner crimped to wires together as an extension. and where it meets the solenoid was really messed up. so I'm thinking of just replacing the starter considering before this problem occurred it was starting to slow down, and replace the bad wire.
Old Jan 23, 2012 | 08:13 PM
tje2015's Avatar
tje2015
http://www.car-stuff.com/store/index...=Ford&md=F-350
Again can anyone help me out with which switch to buy? I just have no idea. ^^Above is the link to site where i was looking.
Old Jan 23, 2012 | 10:30 PM
84-6.9L's Avatar
84-6.9L
So apparently there is an old style switch and a new style.
If I were you I would get ahold of FORDF250HDXLT he is the resident E4OD guru, and he can give you the answers you seek, with the E4OD I can only guess, the C6 is more my style.
Old Jan 24, 2012 | 07:17 AM
tjc transport's Avatar
tjc transport
i ain't rite
what trans do you have? that will determine what switch you need.
Old Jan 24, 2012 | 02:28 PM
eatont9999's Avatar
eatont9999
The first one on the second link looks like what I have on my 91 E4OD.
Old Jan 24, 2012 | 03:26 PM
tje2015's Avatar
tje2015
Well its a 91 f350 automatic diesel, im guessing the e40d
Old Jan 24, 2012 | 03:33 PM
eatont9999's Avatar
eatont9999
Yep, you have the E4OD.
Old Jan 24, 2012 | 03:48 PM
tjc transport
i ain't rite
does it have an overdrive trans, or just a 3 speed?
you could still get the C-6 in 91
Old Jan 24, 2012 | 04:17 PM
tje2015's Avatar
tje2015
Its got the overdrive button, but again, it is automatic.
Old Jan 24, 2012 | 04:32 PM
tje2015's Avatar
tje2015
C6 is Manual only right?
Old Jan 24, 2012 | 05:47 PM
eatont9999's Avatar
eatont9999
The C6 is an automatic 3 speed transmission that is mechanically operated by vacuum. The E4OD is computer controlled and has 4 speeds, one of which is overdrive.
I didn't know you could opt for a C6 in 91. I've never seen a 91 with a C6.
Old Jan 24, 2012 | 07:27 PM
  #28
tjc transport
i ain't rite
you could get the C-6 as an option up till 96
Loosenut53
Mar 12, 2016 10:00 AM
rob2777
Mar 10, 2015 10:37 PM
BigOrange1977
Aug 17, 2014 09:25 AM
EEBuckeye4Life
May 22, 2014 02:22 PM
tjustice
Jun 3, 2013 08:26 AM
