P0478
Old Jan 19, 2012 | 03:51 PM
Sarge261's Avatar
Sarge261
P0478
I have customer that has a 00 F-350 with a 7.3. Been working on it for a while, got all of the issues ironed out but 1, I have a reoccuring P0478 code. It doesnt turn the CEL on but the code shows up if you scan it.
I did install a FORD turbo pedestal, and set the valve accoring to the directions. The old one was leaking oil like a SOB and the valve was sloppy. So I figured at 133k it was time to replace it.
My question is, is there something I missed or did wrong? Im not a 7.3 guy, I do a ton on thr 6.0's and its been a while since I had a 7.3 in the shop. I forgot how slow these 7.3's are stock.
Thanks for the help,
Sarge
Old Jan 19, 2012 | 06:50 PM
BigAlsPSD's Avatar
BigAlsPSD
The 478 is a code for the sensor on the front of the motor. Usually a clogged EBP tube or bad sensor.
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old Jan 20, 2012 | 07:41 AM
Sarge261's Avatar
Sarge261
Thank you sir, that was the next thing I was going after but wanted to make sure I was on the right path.
Sarge
rebauto
Jun 28, 2019 02:09 PM
hakukamana
Feb 26, 2013 10:43 PM
problemchildsmom
Mar 10, 2009 07:04 PM
Pigeon
Jun 7, 2005 02:16 PM
