Oil Leak
Old Jan 19, 2012 | 12:11 PM
buckhunter64's Avatar
buckhunter64
Oil Leak
I need some help
I have a 2006 F250 S/D and it has started to leak oil from the top of the motor on the passengers side runs down the bell housing on top of the starter then the trans line just a light stream anyone know what has happend or what i need to do to get it fixed.
Thanks
Old Jan 19, 2012 | 12:25 PM
powerstroke72's Avatar
powerstroke72
Which engine?
Old Jan 19, 2012 | 12:30 PM
buckhunter64
engine
6.0 diesel
Old Jan 19, 2012 | 12:34 PM
powerstroke72
Originally Posted by buckhunter64
6.0 diesel
Okay, I've moved your thread to the 6.0L Powerstroke Diesel forum. You should get a better response here than in the Super Duty forum.
Old Jan 19, 2012 | 04:08 PM
zhilton's Avatar
zhilton
Could be a couple of things....rocker cover, oil pressure sensor/o-ring, might be the ICP but I have my doubts it would flow that far back (plus you'd see it on top of the valve cover). Also could be oil leaking from one of the turbo lube lines.
Old Jan 19, 2012 | 04:19 PM
buckhunter64
You don't thank it would be the high pressure oil pump
Old Jan 19, 2012 | 04:31 PM
zhilton's Avatar
zhilton
It's possible, but you'd have a hot start issue...I'm pretty sure if it's leaking out the back of the engine it wouldn't start once the truck warmed up.
Old Jan 20, 2012 | 04:14 AM
npccpartsman's Avatar
npccpartsman
It might be the high pressure pump cover but not the pump itself. Check the blue CAC elbow tube at the turbo for a crack/split, turbo oil supply and drain lines, and the oil pressure sensor. Might be spilled oil from an oil change. Those are the only places on top of the motor I can think of. On the passenger side you could have a valve cover gasket or glow plug harness o-ring leaking.
Old Jan 20, 2012 | 04:17 AM
bismic's Avatar
bismic
Don't understand what you mean by a "light stream" - is it a constant flow?
If there is no flow (only drips) it could be that the CAC boots are seeping (oil from the ccv system).
GeneLaw1
Aug 13, 2011 01:02 PM
tnracer93
Dec 31, 2010 02:54 PM
Gary A.
Feb 21, 2008 06:48 PM
kkoon
Jun 7, 2006 09:17 AM
