Turns and Turns
Old Jan 19, 2012 | 11:12 AM
Mitch1407's Avatar
Mitch1407
Turns and Turns
So every now and then my truck decides to not start. It just turns over and over. I wait for "WTS" light goes off, no CEL but it just spins and spins. After about 3 or 4 seconds of not starting, I recycle the key and it sputters to life.
any opinions? No tuner, chip, or any other computer mods.
Thanks fellas!
Old Jan 19, 2012 | 11:16 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
First off, the WTS light has nothing to do with the glow plugs staying on. The GPs will stay on for 2 mins after you turn the key on when cold. Try waiting for about 1 1/2 mins after you turn the key on before trying to start the engine. Let us know if that helps. If not we can go further into this.
Old Jan 19, 2012 | 11:25 AM
Mitch1407's Avatar
Mitch1407
I would say that that was the reason, but it was about 50 degrees when I just tried it. Would the glow plugs really inhibit it from starting at 50*? Also I just started it yesterday at about 28 degrees in the morning no problem same routine. Its a very sporadic occurrence but it seems like its just getting no fire signal from the PCM or something. Would the CPS be a cause? To the best of my knowledge its the original.
Old Jan 19, 2012 | 12:02 PM
miller_feed
Check all be battery connections and the grounds. Have you tested the batts while cranking to make sure you are getting at least 10.5 volts? If you have an AE you could check the the ICP while cranking to be sure the HPOP is putting the right psi to start the engine. You could change the CPS if you have a spare handy. Make sure the oil in the HPOP is close to being full. These are some of the things that will cause a no start.
Old Jan 19, 2012 | 12:47 PM
jwhitetail's Avatar
jwhitetail
Go to walmart and get the Power service white, arctic service. That should help. Deisel fuel is cheap junk. JMOP. put alot off it in more than it call's for.
Old Jan 19, 2012 | 01:41 PM
PaysonPSD's Avatar
PaysonPSD
Here's some FYI for starting requirements.
10.5v cranking volts is not an absolute but anything lower could be a problem.
Old Jan 19, 2012 | 08:20 PM
JonathanN's Avatar
JonathanN
GP's can keep it from firing at 50... with mine, 60* and below I could pretty much forget it. Check your GPR... sounds like it's being sporadic. I had my truck do that once this winter, but it hasn't done it since. I cranked after the WTS light went out and it just turned. Cut the key off, then back on, waited for the WTS light to go out, hit the key, it fired off.
Old Jan 22, 2012 | 10:53 PM
Mitch1407's Avatar
Mitch1407
John, thats exactly what mine did, I'll be sure to check the GPs and GPR. Ill try and have some cranking data gathered, but being so sporadic I don't know if I will be able to catch it.
Many thanks! Reps being sent!
Old Jan 22, 2012 | 10:56 PM
JonathanN's Avatar
JonathanN
What I'm thinking about doing is rigging up a GP LED so that next time it screws up, I can tell whether or not the gpr kicked in or not. Might be worth doing for you...
Old Jan 22, 2012 | 11:10 PM
Mitch1407's Avatar
Mitch1407
Im going to do that with the gauge kit from riff raff when I get the $$$
Old Jan 22, 2012 | 11:13 PM
JonathanN's Avatar
JonathanN
In the mean time, might could just run an ugle nakes LED up into the cab... it takes a 470K or 560K (somewhere around 560... I can't remember) resistor with the LED to run off a 14v.
Bjpford350
Jan 31, 2012 04:45 PM
uscav88
34
Jan 24, 2011 12:25 PM
bmccartney
Oct 5, 2010 07:51 AM
dmunns
Nov 29, 2007 12:32 AM
gtlegacy
Jan 8, 2007 08:55 PM
