2wd front sway bar interchange calling #dummy
01-18-2012, 06:12 PM
on
Will the brackets on the front of the radius arms for the sway bar links of a 77 f250 2wd interchange with a 77-79 f100 2wd
01-18-2012, 07:52 PM
Bracket, front stabilizer bar mounting
D5TZ-5C499-A
Fits: 75-up E/F100-350 Quan req-2
They'll fit. Also, r&l are the same
01-19-2012, 12:17 PM
on
not talking about the ones on frame but the ones just in front of the axle
01-19-2012, 01:29 PM
Quote:
Originally Posted by
boss66
That's what these are, they attach to the front axle, in front of the coil spring and radius arms. They
ARE NOT the ones that attach to the frame. The ones that attach to the frame are D5UZ-5486-A.
01-21-2012, 02:57 PM
on
So will the van swaybar work also
01-21-2012, 03:00 PM
boss66
Don't know about the sway bar itself but the brackets are the same, I'll look up the swaybar and see what the book says.
01-21-2012, 03:01 PM
on
Also will the rear sway bar assy from a F250 2wd work?
01-21-2012, 03:13 PM
The front sway bar themselves are different between trucks and vans.
I'll check the rear sway bar
01-21-2012, 04:13 PM
Illustration Section 53, Page 14 ~ Front Stabilizer Bar ~ 1975/ F100/350 2WD
No rear swaybar (5A772) listed for Econolines, F250/350 only and there were 4 different types.
Rear sway bar listed for 1978/79 Bronco's: D8TZ-5A772-A (not listed in the truck catalog).
01-21-2012, 05:28 PM
Like Bill said, there are no sway bars for the rear of the F100. You could probably modify the brackets to make the F250 bar work but I don't know how much work that would involve.
Kelpy1
19
01-31-2017 01:09 AM
Crop Duster
02-26-2016 01:49 PM
Lagniappe
09-07-2015 05:40 PM
Brian0445
12-21-2004 10:28 PM
David
Offroad & 4x4
04-05-2000 06:23 PM
1963 ,
1978 ,
1999 ,
250 ,
2wd ,
73 ,
77 ,
bar ,
bars ,
d5tz5c499a ,
f100 ,
f250 ,
ford ,
stabilizer ,
sway ,
trucks
