Code 83
Old Jan 18, 2012 | 02:12 PM
Ford Breakdown's Avatar
Ford Breakdown
Code 83
Been having trouble with my '86 Ranger running rough, stumbling lately. Got a code reader and the first code that came up was "83" in the KOEO which the code book says is failed EGR solinoid or a failing low speed fuel pump relay, the Haynes manual lists "84" as EGR problems, doesn't list an "83". Any suggestions which to pursue and how? Would checking fuel pressure at the shrader valve help, or would that just tell that the high pressure pump is working? Would appreciate any suggestions.
Old Jan 19, 2012 | 08:18 AM
pawpaw's Avatar
pawpaw
The code P083 - EGR control circuit failure (1984-1990), suggests something is wrong with the circuit that controls the EGR valve.
So begin with an inspection of vacuum lines & electrical connections to the vacuum switching valve thats used to control the EGR valve. Apply vacuum with a hand pump, to check the VSV & EGR diaphragms & lines, to make sure they're holding vacuum & that the interconnecting vacuum lines are in good shape, not dryrotted, cracked, worn through, loose fitting, ect. When you apply vacuum, you should see the EGR valves pintle move & hold steady, unless the EGR valves diaphragm is leaking vacuum. The VSV should also hold vacuum.
Given the vintage of your ride, what kind of shape is the EGR valve in????
Some thoughts for consideration, let us know what you find.
RobboSRT
Jan 24, 2009 01:06 PM
f100guy
1997 - 2003 F150
Jan 17, 2009 09:37 AM
fixingbus
Nov 19, 2006 09:03 AM
clark714x4
22
Apr 21, 2004 07:47 PM
PAUL_2
Mar 16, 2002 11:46 PM
