Small Flushmount Toolbox?
Old Jan 22, 2012 | 12:49 PM
Greg B's Avatar
Greg B
They do make side boxes that go partially over the wheel well. That would leave the center of the bed front to back open to haul with.
Old Jan 25, 2012 | 09:43 PM
D-mon's Avatar
D-mon
yea the wheel well boxes like that aren't too bad really. Not sure what kind i should get it.
Old Jan 29, 2013 | 03:14 PM
heathkiks's Avatar
heathkiks
Has anyone come up with a solution to this yet? I am about ready to build a box to my specs. I do like the looks of the Tuffy products, but they are not available where I am at.
Old Jan 29, 2013 | 05:01 PM
okgearhead's Avatar
okgearhead
You might try Tractor Supply or Attwoods, they both carry truck boxes. I've got one that might be what your looking for. I'm not at home right now, but when I get back to the house, I'll take a pic and put it on here. I think it's 12" deep, maybe 15" tall, maybe 32", 34"across. It's made by Delta.
Old Jan 30, 2013 | 06:58 AM
Ford8502's Avatar
Ford8502
OP, take a look at this Delta box:
Delta Champion 429000 Bright Aluminum Portable Truck Tailgate Chest : Amazon.com : Automotive
It's model #429000, and is available at other places but they don't show the correct image like Amazon does.
Auto Anything has a lot to chose from too.
Truck Tool Boxes - Best Prices & Reviews on Crossover, Portable & Side Mount Pickup Truck Toolboxes
Old Jan 30, 2013 | 11:35 AM
heathkiks's Avatar
heathkiks
That last box from Amazon is closer. Ideally, I would want the same as the original poster... Full 60" length (styleside), ~12" wide, 12-18" deep.
Old Jan 30, 2013 | 11:39 AM
RA11925's Avatar
RA11925
Trailering
That is almost exactly what I was looking for! Only concern would be how to mount it as I believe its designed to sit in the bed. Thanks for the reply.
Old Jan 31, 2013 | 07:30 AM
Ford8502's Avatar
Ford8502
After reading your post, I thought, "that WOULD be nice" so I started looking too. I figured a small frame with legs along each side could lift it above the bed to any height you would want. You might be able to build a frame to sit in the side grooves of the bed too.
Old Jan 31, 2013 | 12:11 PM
parker245's Avatar
parker245
I ended up getting a low profile box that sits on top of the bed caps across the front of the bed. I still have room to put things under the box. If I think about it, I'll snap a picture of it and post it.
All my previous trucks had 8' beds so the short bed has taken some getting used to. I'm a Scout leader for my sons Scout Troop and as such, we go camping a lot. Losing that extra space has been a pain until I was able to get the Troop a Scout trailer to haul gear in. But I can't just go get the trailer anytime and use it to haul other material for my personal use.
Old Jan 31, 2013 | 01:34 PM
okgearhead's Avatar
okgearhead
I got some pics of my Delta box #810000. It has mounting brackets that mount to the bed, then the box locks onto the brackets, so you can take it out when you need the whole bed. It also has handles on each end. The measurements are 10 3/4"deep, 12 1/2" tall, 32" across. I mounted a ammo box on the end to hold my tow chains, their kinda rusty. The pics are in my gallery, I still haven't
figured out how to post pics to a thread with my iPad.
Old Jan 31, 2013 | 01:38 PM
04XLTRUNNER's Avatar
04XLTRUNNER
Might want to check out these from Deezee.
Wheel Well Tool Boxes
Old Jan 31, 2013 | 01:46 PM
johnday's Avatar
johnday
I've looked for years for a crossbox that I could mount at the rear of the bed, with a cap, and still be able to open the lid on it. Never have found anything. I've also kicked around for years thinking about making what I want. Just need it deep enough to carry tie down chains, snatchum strap, and assorted chain hardware. Don't want it too deep, maybe 6-10" is all, so I could still slide crap under it. I've looked into those behind/in front of the wheelwell things, and liked the plastic ones that hinged out, but, I really don't feel like cutting holes in my plastic bedliner, let alone using sheetmetal screws through the sides of the bed. I like something that basically hangs from the toprail, over the flange on my cap. Maybe I need to weldup something, patent it, and go from semiretirement, to fulltime retirement, richly that is.
Old Feb 2, 2013 | 08:10 PM
  #28
heathkiks's Avatar
heathkiks
Finally found what I was after (close enough), commercially.
Northern Tool + Equipment Aluminum Flush-Mount Side-Bin Truck Box — Diamond Plate, 60 1/2in.L x 12 1/2in.W x 10 1/2in.H | Side Mount Boxes| Northern Tool + Equipment
Yamaha0219
Aftermarket Products
Feb 24, 2011 06:56 PM
Wayne64
2009 - 2014 F150
Jan 26, 2010 02:54 PM
Jack_99V10
New York Chapter
Aug 24, 2007 07:08 AM
s.squared-39
Jul 19, 2007 07:20 PM
n6nfg
Jul 8, 2004 06:53 AM
