Aftermarket Products
Sponsored by: Worksport
Mounting Tool Chest
Old Feb 13, 2011 | 10:43 AM
Yamaha0219's Avatar
Yamaha0219
Mounting Tool Chest
I bought a tool box/chest (the kind that sits on the floor of the bed) off Craiglist. Im not too excited about drilling holes in the bed to mount it, anyone have any good alternative mounting ideas? Its about 56" wide so it takes up most of the bed.
If no one came up with anything creative I think I'm just going to ratchet strap it from moving, since the box itself can lock and I'm looking at getting a Bakflip too (currently have a Leer cap that I want to take off).
Old Feb 13, 2011 | 10:10 PM
ricochet's Avatar
ricochet
I have a weather gaurd tool box and I used a 2x6 placed in the little indentations in the side of the bed to hold it in place. I actually had to place a 2x4 between the box and the front of the bed so the lid would open all the way and then the 2x6 worked perfectly. good luck
Old Feb 14, 2011 | 07:29 AM
ReAX's Avatar
ReAX
You should have strap hooks in the front of the bed, pick up some eye bolts, washers and turn buckles. Run the eye bolts through the side of the box and use the turn buckles to secure it to the hooks.
I've also put them in with riv-nuts and it turned out pretty well, but you do have to drill into the bed to put them in.
Old Feb 14, 2011 | 08:16 AM
Yamaha0219's Avatar
Yamaha0219
Thanks for your ideas guys.
I'm probably going to mount it this weekend. Thinking about putting a 2x4 or 2x6 across the front of the bed (hopefully theres some notches in the bed liner for it that far up) and screw the back of the box to that from the inside. That way I can unscrew it from the inside and take it out if need be, and the whole system should be too heavy when loaded to get stolen.
Old Feb 19, 2011 | 04:37 AM
SAWMAN556's Avatar
SAWMAN556
You'd be surprised what people can steal. I bolt down my gun safe(in the house of course) and screw down my truck tool box. I doesn't bother me to have to drill a few holes.
Old Feb 19, 2011 | 11:41 AM
Fasttimez's Avatar
Fasttimez
You can remove the 2 front bed mounting bolts, drill holes in your chest and run the bed bolts through your chest....that way you don't have to drill holes.
Old Feb 20, 2011 | 01:12 PM
BigPigDaddy's Avatar
BigPigDaddy
I installed a loop handle on each end of my box so I can pack it in and out of the truck when I need to. The handles were about $3 each at the hardware store. I then use a bicycle cable run through my box handle and through the bed tie down loop with a master lock to tie it all up. That way I can move the box around for different loads, but it can't be stolen (without bolt cutters).
Old Feb 20, 2011 | 05:47 PM
mfg02's Avatar
mfg02
The most inventive way I've see for bed boxes, like you're talking about, and the regular tool box is high strength velcro. Put one piece on the clean surface of the truck (bed or side rails) and the other piece on the box. It is amazing how well it holds and you'd really be surprised at the minimal bouncing sound some people have with j bolts and such. If you have a bed box like your talking about I do a diaganol pattern about five strips on the bed and an opposite running diaganol pattern about five strips on the box. That way they don't have to perfectly line up. And you can remove the box real easy if you need to.
Old Feb 24, 2011 | 06:56 PM
jwill8957's Avatar
jwill8957
I bought one of those things that extend acreoss your bed from side to side that hold luggage or other stuff in place for 14.99 at walmart. I put it in front of my chest and tighten it up and its good to go plus its very easy to remove if need be
adbscu
Jan 19, 2017 12:36 AM
johndeerefarmer
All Things Towing
17
Sep 18, 2016 09:48 PM
ufvj217
Jul 8, 2016 09:02 PM
Champ198
Jun 12, 2016 06:46 PM
Banage
Mar 17, 2012 06:03 PM
