Ok guys went to the junkyard today and found what I believe to be a mark VIII fan. You guys are referring to the Lincoln Mark VIII right. How do I tell which one is only a one speed model.
Ya know we're gonna want pics and a write-up on how ya make that fusebox, harness & circuitry work on your rig with the M8 fan upgrade... Say, you've already got the sensors on the plugs!
Metric threads? In that case, you'll also need sensors that are spec'ed in Celsius instead of Fahrenheit. J/K!
The fan I got was from a MKlll also but the wiring plug only had 2 connectors; single speed. But, The fan plug has 3 pins; Ground, low & hi. It works as both low and high! I put mine thru an amp gauge and it was drawing 30 amps on hi. They sure do put out some CFM's....
Thanks again HIO It was 26* here this morning so it might be a day or two before I need elect. cooling.....
:Question: I want to do this to my Navigator, im going to the junk yard this weekend so which fan would be best? MarkVII, Taruas Or Winsder? and besides the fan what else should i take? thankz
