Question about electric fan
Old Feb 22, 2013 | 01:19 PM
seajr1978's Avatar
seajr1978
I have a mark viii fan single speed I'm about to install but can't decide between a relay setup or pwm controller setup which would work best?
Old Feb 22, 2013 | 01:58 PM
fmc400's Avatar
fmc400
MSEE
A relay-controlled fan means the fan is either on or off; if it's off, the fan does not spin; if it's on, the fan spins at full speed. A PWM-controlled fan means the exact speed of the fan can be adjusted within some range.
PWM fan controllers are expensive and there is no point to have one for this application, in my opinion. With a relay-controlled setup, you should already be using a temperature switch to cut off the relay under a certain temperature. That is already one form of modulation. With the simple relay setup, the fan will be off below a certain temperature, and it will be on all the time past a certain temperature. There is limited quantitative gain in dynamically adjusting the speed of the fan once it's on with a PWM controller. I don't see the point when in reality you don't care that your coolant temperature fluctuates within a few degrees.
kountzecobra
2009 - 2014 F150
Mar 13, 2019 06:27 AM
Don Bordeaux
1997 - 2003 F150
Jun 7, 2018 07:49 PM
1986F150six
Nov 6, 2016 09:27 AM
BlitZ_
1997 - 2003 F150
Sep 3, 2013 04:36 PM
6.0techwannabe
15
Oct 29, 2012 04:35 PM
