AE and injector problem - Advice Please.
Old Jan 17, 2012 | 01:47 PM
nlemerise's Avatar
nlemerise
Last night, I got a call for an emergency run to Green Valley, AZ using my pickup (e99, F350, 7.3l). The temperature was 1 degree and the truck had not been driven in a week or so. I was in a hurry, so I did a quick glow plug run of maybe 30 seconds. Fired-up fine (gotta love 5-40 syn) and I left. Pulling out of my driveway there is a hill and I got on the truck a wee bit while the engine was dead cold still and it through the "Service Engine Soon" light and began to run weak. I drove it about 10 miles hoping that it would get better, but it didn't. Called my company and gave up my run (losing $1000 ). Drove back home and parked. I thought it was an injector problem on one cylinder and let the truck sit overnight. Took my AE out this morning and started the truck and let it warm up for 30 minutes, recorded codes, and then cleared them. Then did a KOEO test and got the following codes:
P0605
P0640
P1277 Cylinder 7 High to Low Side Open
That P1277 then made me do a buzz test. Cylinder 7 silent!
So I am thinking the problem lies in the UVCH on the passenger side, cylinder 7. Before I tear into it, I just want to check with the more experienced that they diagnose this as I do. What do you folks think?
Old Jan 17, 2012 | 01:58 PM
Bonanza35's Avatar
Bonanza35
I think you got it right. If silent on 7 it mit be the relay only. Ohm it out that should tell.
Chet
Old Jan 17, 2012 | 02:44 PM
nlemerise's Avatar
nlemerise
Alright, pulled the valve cover and did the 50 cent mod to passenger side (about time you say ). Redid the buzz test and now cylinder 7 buzzes . I guess the next step is to ohm out the UVCH connection, correct?
Old Jan 17, 2012 | 03:33 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Did you take it for a ride to see if all is well now?
Did you run the CCT test?
Old Jan 17, 2012 | 03:36 PM
nlemerise's Avatar
nlemerise
Rick, I started it and it purrs...Have not run any tests other than a buzz test after I reseated the UVCH connection. Can't find my DMM (so I can't ohm out the connection), so I am going to button it up. What do you think? Should I run a CCT before I button her down?
Old Jan 17, 2012 | 03:43 PM
miller_feed
You can run the CCT any time you want. Did you check to make sure oil is coming out of each injector?
Old Jan 17, 2012 | 04:10 PM
nlemerise's Avatar
nlemerise
Yes, I check oil flow before I torqued everything down. It is buttoned up now and I just finished attaching the IC pipe. Off for a ride!
Old Jan 17, 2012 | 04:26 PM
miller_feed
. Let us know how it goes.
Old Jan 17, 2012 | 05:09 PM
nlemerise's Avatar
nlemerise
Everything seems to be back to normal...passes all tests. Anyone have any links to reading about Injection Control Pressure readings (both pressure and duty cycle)?
Old Jan 18, 2012 | 07:47 AM
miller_feed
Cool deal Neal. Is there something in particular you are asking about with the ICP?
Old Jan 18, 2012 | 09:18 AM
nlemerise's Avatar
nlemerise
Thanks Rick! Well believe it or not, the truck has never given me any kind of problem in all the time I have owned it. I bought the AE because I live in the back country and it is a long way to anywhere to have someone diagnose or fix a problem (and I love to fix everything thing I can fix myself). So anyway, the AE paid for itself the last couple of days. When I took it for a test ride I watched pressure and duty-cycle and it made me think about "what's normal"? Thus, the question about reading material...
Old Jan 18, 2012 | 10:05 AM
Shake-N-Bake's Avatar
Shake-N-Bake
Neal,
Here is some reading material for you.
https://sites.google.com/site/woodnt.../autoenginuity
Lots of great info on Ken's page. In particular, the HPOP Health check
https://docs.google.com/viewer?a=v&p...NTA0NmMxZjRjYg
From what I've seen, if the DC maxes out around 50%-ish at WOT then that is a good sign your HPOP is fairly healthy. Generally speaking...
Old Jan 18, 2012 | 10:15 AM
nlemerise's Avatar
nlemerise
Exactly what I was looking for...thanks for the links Greg and thanks for the writeups Ken!
No7Brand
May 15, 2018 03:15 PM
strokersace
Aug 20, 2010 06:44 PM
cartmanea
Apr 30, 2010 11:08 AM
Bear River
Aerostar
62
Mar 21, 2008 02:36 PM
dchaney71
Dec 18, 2006 09:56 PM
