2000 f250 running rough, now not starting - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
Old 05-12-2018, 01:30 PM
No7Brand
No7Brand is offline
No7Brand is starting off with a positive reputation.
Hey, guys. I was hoping for a little help. A few days ago my uncle was driving the truck and said it was running fine, then he shut if off, made a phone call and started it back up. It sounds terrible, running very rough. Limped it home and hooked it up to autoenginuity, got the following error codes
P1670 electronic feedback signal not detected
P1316 injector driver module codes detected
P0470 exhaust pressure sensor( I think this one has always been on there)
P0261 cylinder 1 injector circuit low
P1295 injector multiple faults-bank 1
P0605 internal control module read only memory error
P0263 cylinder1 injector circuit contribution/balance fault
P0269 cylinder 3 injector circuit contribution/balance fault
P0275 cylinder 5 injector circuit contribution/balance fault
P0281 cylinder 7 injector circuit contribution/balance fault
Some of those I got when i ran the injector buzz test and the cylinder test. Now, after I cleared the codes the truck won't start. About 5 years ago we had the same symptoms I believe (although different error codes I think) and the problem was the pigtail connector for the injectors on the drivers side. Do you think this could be the same thing except on the passengers side? Didn't want to start tearing everything apart to get to it if any of you thought there might be something easier to check first or something else that might be wrong. Thanks for any help!
Old 05-12-2018, 01:34 PM
Walleye Hunter
Walleye Hunter is online now
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
All on one side I'd suspect wiring on the passenger's side. Check around the 42 pin for worn/shorted wires where they rub on the valve cover while you're at it but concentrate on your UVCH connections on the passenger's side.
Old 05-12-2018, 02:27 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Originally Posted by Walleye Hunter View Post
...but concentrate on your UVCH connections on the passenger's side.
Yup, my thoughts too.
Stewart
Old 05-15-2018, 02:30 PM
Josh Ross
Josh Ross is offline
Josh Ross is starting off with a positive reputation.
Google nine pin ohm test or glow plug ohm test. There are good write ups on here on how to do.
Old 05-15-2018, 02:55 PM
No7Brand
No7Brand is offline
Thanks for the info guys. I changed the gasket harness last night and still have problems. It seemed to run a little smoother when I first started it up after changing, but the second time I started it and sounded worse then before. Only error codes I get now are
I will google the nine pin test now and start testing wires.
Old 05-15-2018, 04:15 PM
No7Brand
No7Brand is offline
Well, I'm an idiot. Found the problem. Walleye Hunter had it right. wire was rubbing on the valve cover. I really should have looked there first! haha. oh well, Thanks for the help!
augalexand86
08-05-2017 10:50 PM
caedo
01-07-2015 01:50 PM
Dustin98SS
11-13-2002 10:30 AM
Quick Reply: 2000 f250 running rough, now not starting
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
