help with codes
Old Jan 17, 2012 | 09:07 AM
jozan's Avatar
jozan
help with codes
have a 95 f1501 5.8 auto 4x2, the problem olny happens when its warm outside above 60 it seems and after been at operating temp for 15 miles or so, unless i stop between work the after start it will first set engine light, then the light goes off (sometimes) and start bucking and jerking like the fuel pump or the key is being turned off it can get very rough. sometimme if the pedal is pumped it will speed up as long as it above 2500 rpm , but after you let off cause im going like 75 it will start all over its has new coil dist, cap rotor, control module, and rear fuel pump and regulator, the codes are 126,128,172,212,452,542.
Old Jan 17, 2012 | 09:29 AM
jozan's Avatar
jozan
and a new pcm (reman from oriellys) none of theese parts are over 6 months old it had this problem several years ago i even took to a mechanic he couldnt find it so i replace the mentioned parts then and it stopped, and we really quit driving it im back in it now and its started again all the parts had warranty so i been replaceing them but not working so far
1956_F100
20
Apr 25, 2016 06:57 AM
Lzryde
Mar 24, 2015 08:38 AM
bielenbergr
Jun 28, 2011 12:19 PM
randrm
Aug 7, 2007 05:59 PM
rescuedranger
Sep 28, 2006 08:49 PM
