Bronco II Ford Bronco II
Timing
Old Jan 17, 2012 | 01:18 AM
shapechanger101's Avatar
shapechanger101
Timing
So i just replaced the heads on an 87 B2. When i re-installed the dizzy, i set the engine to TDC, and put in the dizzy with the rotor pointed at the number 1 cylinder. Now i can only get it to run if i put the number one plug wire on the post that is right in-front of the rotor pointing the number one cylinder.
Heres the problem, I can only find the timing marks with the timing gun if i place the timing light clamp plug wire number 3
Any input will be greatly appreciated.
Old Jan 17, 2012 | 12:18 PM
Ruffinit's Avatar
Ruffinit
When trying to time it are you disconnecting the wire (that hangs on the firewall)? If not, you won't time it properly. Check your Haynes or Chilton.
Even my long time mechanic (pro) didn't do that and wasn't able to get it timed properly.
Old Jan 17, 2012 | 01:38 PM
shapechanger101
Yes i have that removed.
Old Jan 17, 2012 | 08:02 PM
Ruffinit's Avatar
Ruffinit
Did you remove the distributor? Possibly one tooth off?
Old Jan 17, 2012 | 11:27 PM
shapechanger101
Yes as mentioned in my original post, i don't believe i am a tooth off, i got it in their pointing directly at the number once cylinder.
Old Jan 20, 2012 | 12:58 PM
Ruffinit's Avatar
Ruffinit
Yep, I saw that in your post, but the teeth are small. Sorry, I'm out of ideas. I'm sure you'll noodle it out.. Let us know what you find.
revans9295
27
Feb 27, 2012 10:04 AM
gt4660
Jul 28, 2010 02:49 PM
DT 466Man
16
Oct 2, 2005 08:18 AM
model t
Jan 4, 2002 09:24 PM
Dog_Brains
Oct 19, 2001 10:45 PM
