code 41
Old Jan 16, 2012 | 04:11 PM
1stormseekr's Avatar
1stormseekr
code 41
Okay the only code i am pulling off my truck is a code 41,only problem is this bad boy is running rich. Have not checked the fuel pressure yet but i went from 7-8mpg to 3mpg.1989 f350 460.
Old Jan 16, 2012 | 04:35 PM
Slip ford man's Avatar
Slip ford man
Is she a duel tank, are they both functional?...
Old Jan 16, 2012 | 06:14 PM
1stormseekr
lol was a dual tank, converted her over to a single 38 gallon. How would that effect her when she is running rich?
Old Jan 16, 2012 | 06:47 PM
deeznuts822's Avatar
deeznuts822
Check the fuel pressure, Usually a bad fuel pressure regulator will allow the engine vaccum to draw fuel causing a rich condition. A simple test is pull the vac line from the regulator and see if theres any fuel in the line or coming out of the nipple. The regulator can be found on the fuel rail.
Old Jan 16, 2012 | 06:59 PM
rla2005's Avatar
rla2005
Any exhaust leak upstream or near the O2 sensor can trigger a lean code.
Old Jan 17, 2012 | 12:29 AM
1stormseekr
did that check on the regulator, small signs of a exhaust leak near the o2 sensor but not on the upstream side...o2 sensor is mounted almost like a cross over pipe between both sides of exhaust....going to check the o2 sensor next.
Old Jan 17, 2012 | 04:09 AM
Slip ford man
Was thinking that your 3MPG may have been based on faulty tank readings...sometimes they can feed or starve each other because of a valve fault...your former mpg 7/8 is terrible too, when was the last tune up? how much compression does she have left in her?
Old Jan 17, 2012 | 08:08 AM
1stormseekr
lol wish it was faulty tank readings...using the odometer and gallons put in the old gal. Running millitary tires so the odometer is off a little. With stock tires it was about 12.New tuneup stuff within the last 3months.
Old Jan 17, 2012 | 08:12 AM
rla2005's Avatar
rla2005
How near? even if it is a little downstream it can effect the O2 sensor readings.
Old Jan 17, 2012 | 09:31 PM
1stormseekr
going to fix the leak,just in case before i check the sensor. about 2". This is the first ford i have owned with this type of setup...lol last ford was a 74 model, and that was 15 years ago.
vintagequest
May 16, 2018 05:11 PM
Sehandly
Mar 2, 2017 09:05 AM
WMNY
Modular V10 (6.8l)
May 19, 2016 08:37 PM
brandon.edwards
Mar 3, 2014 08:39 AM
pete315
Apr 14, 2010 05:41 PM
