1995 5.8L starting issues
Old Jan 21, 2012 | 10:40 AM
  #31
88dually's Avatar
88dually
Have u guys checked the thread 89 350 460 4x4 ?
I think u guys could help. Changed tfi on dizzy, it ran 3 minutes an died again. Pip sensor in dizzy ?
I wanna try this trick now, but wheres the map on a 88 351 ?
Old Jan 21, 2012 | 02:00 PM
  #32
88n94's Avatar
88n94
I think it would be in the engine compartment above the housing that holds the heater core not far from the firewall. I THINK
Old Jan 21, 2012 | 02:11 PM
  #33
88dually's Avatar
88dually
Ok thx, i'll trry it in a couple days when the weather gets better.
Old Jan 24, 2012 | 12:03 PM
  #34
causindrama021's Avatar
causindrama021
Originally Posted by 88n94
I will add to what I said under No. 22. I also had a bunch of weird issues in addition to the fast idle. There were days I would try to start it and it wouldn't start. Try it another day and it would start. Let it sit and warm up to normal operating temperature, shut it off and it would only restart if i held the gas pedal to the floor. Drive it down the road and it wouldn't shift right. Bottom line replacing the TPS solved all these issues as well as the fast idle.
What I'm trying to say is try to fix the fast idle problem and it will likely solve your starting problem as well. Yes, I think it's a sensor.
i noticed right before it crapped out that it wasnt shifting right also. so that may be a problem but i also just replaced the egr valve because it was deff. bad and have now noticed the front cat. glowing cherry red. you know the one where the y pipe goes two into one. and it looks like its all one piece from the manifolds and past the second inline cat.
Old Jan 25, 2012 | 09:01 PM
  #35
causindrama021
nothin new yet
KG4NEL
Sep 29, 2015 06:19 PM
71Hanker
1978 - 1996 Big Bronco
Mar 30, 2009 01:26 PM
Navy Jet Mech
Aug 13, 2007 11:50 PM
matt87
19
Jul 1, 2004 09:26 AM
