Not getting fuel
Old Aug 10, 2007 | 11:40 PM
Navy Jet Mech's Avatar
Navy Jet Mech
Not getting fuel
Before I made a quick stop into Wal-Mart today, my truck ran fine. When I went to go to my next planned stop, the truck tried to take fuel, but instead bucked, shuddered, and died. It has spark, but is not getting fuel. However, when starting fluid is sprayed into one of the intake hoses, it will start and run for maybe three seconds. This is affecting the rear tank--the front does the same thing, but I haven't tried starting fluid with it. I'm stumped and more than a little pissed. Any ideas? Hope it isn't the fuel pump...
Old Aug 11, 2007 | 12:26 AM
Mr. M's Avatar
Mr. M
Fuel pressure regulator. Or the vacuum line attached to it. Make sure the line holds vacuum before you look to buy a new one. Its a cheap junkyard part if you have a pick and pull nearby...
Worth a try
Mike
Old Aug 11, 2007 | 12:39 AM
Navy Jet Mech
Mike, if that happens to be the case, then you just made my day! Now, what do I need to look for/at under the hood?
Thanks,
Dan
Old Aug 11, 2007 | 01:32 AM
Mr. M's Avatar
Mr. M
Thanks,
Dan
Well, I don't have the I6 truck in my driveway as we speak. But I reckon the regulator will be near, along and attached to your fuel rail. The one on my 5.0 is sitting on the driver side of the block near the EVR. Look for a vacuum line running to the top of the device and the bottom return headed to the fuel rail. I believe the vacuum line is red attached to the FPR. If I'm wrong someone will chime in here.
Check along the fuel rail... you will find a bronze looking small cylindrical metallic device (kind of looks like a miniature torque converter with input shaft attached! if that helps) with a vacuum line attached to to the top.
If you have a haynes or chilton manual, they will have a snapshot of the FPR. I have to reiterate, before you purchase another one, test the vacuum on the line first. It might be a cheap vacuum line fix!!
I wish I had a picture to post for you... my 300I6 is 200 miles away.
Good luck!
Mike
Old Aug 11, 2007 | 03:03 AM
Skandocious's Avatar
Skandocious
Here are pictures and instructions for R&R of the 5.0/5.8 FPR, my manual didn't have the 4.9L, hopefully some of the steps will carry over. Good luck buddy.
Old Aug 11, 2007 | 03:31 AM
subford's Avatar
subford
A Fuel Pressure Regulator would not do this.
Either your Fuel Pump Relay is not closing or there is no power to it or your Inertia Switch has tripped.
Try resetting the Inertia Switch by pushing down on the button on top.
Check to see if the Fuel Pump Relay is closing, it should click as soon as the key is turned on and click again one second later when it opens.
If the Inertia switch is not tripped and the Fuel Pump Relay is closing then you may not have any power on the Yellow wire going to the Fuel Pump Relay, this would mean the fuse link has opened that feeds this Yellow wire at the starter relay.
If the Fuel Pump Relay is not closing ground pin #6 of the VIP (test connector) and see if it will close then, if not change out the Fuel Pump Relay.
All of the above assumes that you do not hear the Fuel Pumps run for one second when you turn the key to the run position.
If you do hear the Fuel Pumps run then the injectors are not firing.
Old Aug 11, 2007 | 03:48 AM
Skandocious
Oh well then disregard my post. But now we all know how to remove and reinstall the FPR, including myself
Old Aug 11, 2007 | 11:29 PM
Navy Jet Mech
Subford, you hit the nail right on the head--the fuel pumps don't whir when I turn the key to the run position. I can't imagine why the inertia switch would have tripped, but I know it's quite possible, so I'll check that first.
But assuming that the switch didn't trip, I have a few questions. Where is the fuel pump relay? And if it doesn't close, where would I find the VIP (test connector)--specifically pin 6--and how would I ground it? The same questions would apply to the fused link you refered to. (If this was ever in doubt, I absolutely hate messing around with any sort of electrical system or component.)
Now a couple questions about the fixes. I read--in the Haynes manual, if I remember right--that one is best off buying the fused link from a Ford dealer. Is this true, and would it also apply to the relay? And how much would these cost?
Thanks, all, for the help!
Old Aug 12, 2007 | 08:13 AM
subford's Avatar
subford
Drivers fender next to the EEC Power Relay.
Short (with paper clip) pin #6 to pin#2 or NEG (-) side of battery.
VIP Test Connector
Not 100% sure on a 91 but it may be here.
(Called Diagnostic self test plugs in diagram below)
It would be bolted to the battery side of the starter relay on the fender and be feeding one of the Yellow wires. If you try to pull a fuse link apart and it stretches it is bad.
If you buy a fuse link from Ford or a roll of fuse link wire from an auto parts store you are going to have to crimp butt connectors on each end (or a ring on one end). Fords may come with the connectors I do not know but at any rate get the right size (GA) fuse link.
The relay could be bough from either but check the wiring under the relay socket before buying one.
Old Aug 13, 2007 | 11:50 PM
Navy Jet Mech
Well, I got the truck fixed today. I went to the inertia switch right away--it didn't appear to have tripped, but I popped the button up and pushed it down anyway. Then I went under the hood and took a look. The data link connector was easy to find, so I looked for the realy. After a few minutes of trying to figure out which was which, I said the hell with it and tried starting the truck. And it started...and kept running.
If only I'd known about the inertia switch on Friday...
Thanks for the help, everyone!
JonArmy
Sep 30, 2011 07:23 PM
TheDuke
Apr 28, 2009 08:43 AM
MagKarl
40
Jan 7, 2008 05:27 AM
jeffthompson
93
Mar 3, 2004 07:05 PM
torino man
Jan 25, 2001 10:13 AM
