Steering collar upgrade help
Old Jan 16, 2012 | 08:35 AM
yanknek's Avatar
yanknek
I have convert to an auto floor shift (B&M truck MegaShifter) in my '77 f150.
I know longer want my auto shift lever on the column nor do I want the hole there if I remove it. I could lathe me a part to fit in the hole but I still think it will look bad being there.
Does anyone have an idea or know of a replacement collar that will work?
I have checked the threads but I dont see anyone addressing this issue.
Thanks, Yanknek
Old Jan 16, 2012 | 10:05 AM
mark a.'s Avatar
mark a.
I just used the parts I needed off the donor trucks steering column when I switched mine over to a 4 speed. Used standard columns should be a dime a dozen in your local junk yards.
Old Jan 16, 2012 | 10:14 AM
yanknek's Avatar
yanknek
What did you get yours collar off of. Everything I find has the shift lever (auto and/or manual)? Thanks for your help with this.
Old Jan 16, 2012 | 10:28 AM
mikeo0o0o0's Avatar
mikeo0o0o0
I did a search for the collar used on 4 spd columns, no dealer or obsolete supplier has one. You could search the salvage yards for one. (C3DZ-3790-A Extension, steering column tube).
These are zinc castings, not sure but I don't think you can weld it.
What about using fiberglass and resin and fill in the hole?
Quite often F350's have 4 spd tranny's.
Old Jan 16, 2012 | 10:32 AM
yanknek's Avatar
yanknek
I had thought about cutting of the extender and filling the hole.
I have a friend that owns a parts yard and see if he knows of that part you called out. Thanks for helping.....
Indybeer
Sep 12, 2018 08:46 PM
hillcountryflt
41
Feb 20, 2018 02:07 PM
biggkahuna83
Oct 1, 2012 10:57 PM
tatetodd
Mar 30, 2007 08:29 AM
jody
Sep 16, 1999 06:39 AM
