HPOP installed
Old Jan 15, 2012 | 03:27 PM
fordpride's Avatar
fordpride
HPOP installed
Alright guys I installed a Adrenalin HPOP that I got from one of I members and all I can is WOW. My truck idles smoother, responds and runs a whole lot better/harder So if your running upgraded sticks with a stock HPOP I highly recommend that you upgrade your HPOP
Old Jan 15, 2012 | 03:48 PM
427 fordman's Avatar
427 fordman
That poor trans....
Old Jan 15, 2012 | 03:53 PM
tshrager's Avatar
tshrager
Originally Posted by 427 fordman
That poor trans....
That's what I'm worried about when I get to sticks and chip. I know it's going to be an issue.
Congrats though mike. I bet she pulls well!
Old Jan 15, 2012 | 03:56 PM
fordpride's Avatar
fordpride
It pulls hard. Far as the trans I'm doing a ZF swap or a racer x build
Old Jan 15, 2012 | 10:57 PM
oldbird1965's Avatar
oldbird1965
I'm glad the install and performance worked out for you Mike!
Old Jan 15, 2012 | 11:39 PM
fordpride's Avatar
fordpride
Glenn the preformance is great and the install took me about 3 1/2 hours and that was with cleaning the top of the engine. Thanks
Old Jan 16, 2012 | 05:42 AM
stainlessstroker95's Avatar
stainlessstroker95
Did you use a write up on here or how did you go about the instalating.
Old Jan 16, 2012 | 05:53 AM
fordpride's Avatar
fordpride
I kinda skip threw Cody wright but mostly I just went at it. To me the worst part was getting averting out of the way so you could get to the back of the pump
Old Jan 16, 2012 | 07:20 AM
tshrager's Avatar
tshrager
I used Cody's write up. Nicely written. Took me about 4 hrs or so, but I had a good amount of other things going on as well so it's hard to say.
Old Jan 16, 2012 | 09:03 AM
fordpride's Avatar
fordpride
Yea I still have e fuel and intecooler to do
Old Jan 16, 2012 | 09:15 AM
tshrager's Avatar
tshrager
You're a lucky dog.
Old Jan 16, 2012 | 12:53 PM
fordpride's Avatar
fordpride
I've been gathering parts for over a year and finally getting some time to put them on
Old Jan 16, 2012 | 07:52 PM
oldbird1965
Hey Mike, you lucky dog! I thought I had a successful install and today I blew a fitting on the drivers side hose right at the HPOP. I was in town and left a trail on the way home. I try my hardest to keep a clean driveway and left a nice trail pulling in. I wiped up the mess around the HPOP and started it, now I know where its leaking. It was to hot to work on, tomorrow I'll check it out, the only thing I can think of I over tighten it??? Supposedly, from what I read, there isn't a O ring in our hose's, the SD's do. Does anybody know where to get another hose? I think I've read that a hydraulic shop can make one.
Old Jan 16, 2012 | 08:00 PM
fordpride's Avatar
fordpride
Yep I had two made for about 75 bucks a couple years ago
Old Jan 16, 2012 | 08:03 PM
fordpride's Avatar
fordpride
Don't feel bad Glenn I broke my t-stat housing so kinda of way
