Fuel Sending Unit Question
Old Jan 15, 2012 | 01:04 PM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
We pulled the side tank on My son's 96 F250, the screen had come out of the bottom of the umbrella and the plastic/rubber plug came out of the side of the umbrella. It appears to be some kind of 1 way valve?
Can anyone tell me What direction does it go back in?
Old Jan 15, 2012 | 02:41 PM
Hussler's Avatar
Hussler
Nope, can't tell you, but here is a thread with a picture of the unit but it's for the rear tank ...
https://www.ford-trucks.com/forums/7...ank-issue.html
Scroll down to post #10.
Is it the roll over valve you are talking about?
Old Jan 15, 2012 | 02:46 PM
TurtleRacing
PSD Addict
The valve is in the opposite side in that pic.
Old Jan 15, 2012 | 04:07 PM
DIYMechanic's Avatar
DIYMechanic
If you can give me a better description of what you're looking for, I will go take a picture of the sending unit out of my parts truck and send it to you so you have what you need.
Old Jan 15, 2012 | 04:11 PM
Hussler's Avatar
Hussler
Thanks, I had 50% chance ... finding a pic but ... .
Reps sent.
Old Jan 15, 2012 | 04:35 PM
TurtleRacing
PSD Addict
180degrees from the circles area in the pic. There is a plug that goes inside there, I need to know if there is a small nub facing out or a bigger orange plug..
Old Jan 15, 2012 | 04:36 PM
TurtleRacing
PSD Addict
180degrees from the circle area in the pic. There is a plug that goes inside there, I need to know if there is a small nub facing out or a bigger orange plug..
Old Jan 15, 2012 | 04:51 PM
DIYMechanic
Gotcha! These pics are of the sending unit for the rear tank, but the same design is used for both tanks, they're just shaped different.
I think this is what you were looking for:
Here are a couple more shots of the SU for good measure:
Good luck, hopefully this helps.
Old Jan 15, 2012 | 05:02 PM
TurtleRacing
PSD Addict
That's PERFECT!! Thank You very much!!
Old Jan 15, 2012 | 05:14 PM
TurtleRacing
PSD Addict
OK, does anyone know the part numbers for the rear sending unit and the valve to switch between tanks? I am trying order everything from Rock Auto and their sending units don't REALLY explain what they are for and I dont see the diverter at all.
Old Jan 15, 2012 | 06:07 PM
DIYMechanic
The switch you're looking for is called a "fuel selector switch" and they are EXPENSIVE! I believe the Ford P/N is : Fuel tank selector valve E5TZ9189B. I wish I still had one to send you, but I sold it to a local guy who needed one for a project he was working on. As far as the sending unit goes, I'm not sure of the part number but if you want one, I have one I will make you a good deal on if you don't mind a used one.
Old Jan 15, 2012 | 06:21 PM
TurtleRacing
PSD Addict
How much $$?
Old Jan 15, 2012 | 06:44 PM
DIYMechanic
I will send you a PM.
Osoford
Mar 8, 2017 10:00 PM
garydmundy
Jul 15, 2016 05:14 PM
weez440
Aug 7, 2012 08:44 PM
3D52
22
Dec 17, 2009 05:33 PM
