Sending unit question
Old Mar 6, 2017 | 06:40 PM
Osoford's Avatar
Osoford
I'm in the process of replacing both of my fuel tanks, I picked up a new front tank from autozone today and was going to buy a new sending unit but they didn't have one that matched the unit I pulled out of the old tank. I went to autozone, O'reillys and napa, nobody had one like mine so while at napa I did a little hunting online and the only match I found said it was for a 64-68 mustang. Does my truck have the incorrect sending unit or have you guys had this problem? This is the one that was in my truck
Old Mar 6, 2017 | 07:57 PM
Justin73supercamper's Avatar
Justin73supercamper
I'm going too follow this post I've been looking for the same unit. I resorted to a uses that I found at pick n pull. Seems like the the company that makes the gas tank would have a sending unit.
Old Mar 6, 2017 | 08:04 PM
Osoford's Avatar
Osoford
Here's the unit I found when searching for a 65 mustang, appears to be the same. I'll update when I get mine tomorrow.
http://m.autozone.com/fuel-delivery/fuel-tank-sending-unit/spectra-premium-fuel-tank-sending-unit//ford/mustang/1965/6-cylinders-3-3l-1bl/709583_70442_0?location=
Old Mar 6, 2017 | 08:10 PM
Justin73supercamper
If I'm not mistaken I looked at that unit. The pickup line was 5/16. I need 3/8. And the tabs to keep it orientated in the tank were off. I hope I'm wrong.
Old Mar 6, 2017 | 08:22 PM
Osoford's Avatar
Osoford
There are 2 separate part numbers for that year, one with 5/16 and one with 3/8. As far as the tabs go I guess I'll find out when my new one gets here 😕
Old Mar 6, 2017 | 10:05 PM
march's Avatar
march
Tell us more about your truck. Reg or supercab? 2X or 4X year etc.
Old Mar 7, 2017 | 06:40 AM
Osoford's Avatar
Osoford
Sorry about that, the truck is a 1975 f-150 ranger xlt regular cab 2wd with a 302.
Old Mar 7, 2017 | 07:55 AM
march's Avatar
march
Looks like D7TZ-9275-B with 4.25" float arm. Available here
Sending Units-Broncograveyard.com
Old Mar 7, 2017 | 08:10 AM
Osoford's Avatar
Osoford
Thank you, I always forget about bronco graveyard. That would have saved me a lot of time and headache yesterday.
Old Mar 8, 2017 | 07:13 PM
Osoford's Avatar
Osoford
Thank you for the help, the 65 mustang unit was close but was only a single pin, ordered one from bronco graveyard and it should be here early next week.
Old Mar 8, 2017 | 09:22 PM
march's Avatar
march
I find JBG and Dennis Carpenter and even LMC are helpful......... Even if just to get the right part number. Hope this one works.
Old Mar 8, 2017 | 09:29 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No F100/350 used the same fuel tank sending unit as a Mustang.
1965/68 Mustang & 1967/68 Cougar: C8ZZ-9275-C .. Fuel Tank Sending Unit.
D7TZ-9275-B (replaced D0TZ-9275-D) .. Mid-Ship Fuel Tank Sending Unit / Marked: D0TF-9275-B or D7TF-9275-BA / Obsolete
1970/72 F100/350 with optional 25 gallon auxiliary tank / 1973/79 F100/250 2WD & F350 Regular Cab / 1978/79 F250/350 Crew Cab.
Old Mar 8, 2017 | 10:00 PM
PapaBearYuma's Avatar
PapaBearYuma
Just get a float and use the one ya got!
Just kidding of course...however, most of the aftermarket stuff (selector valves and senders) seem to be 5/16
southtexasidi
May 2, 2020 02:44 PM
cana55
1947 and Older Ford Trucks
Feb 22, 2009 10:25 AM
