Sensor for Parking brake?
Old Jan 15, 2012 | 09:39 AM
robs01f250's Avatar
robs01f250
Now that it is winter I start the truck in the I let it sit and warm up at idle. The only problem that I am having is the truck will not idle up unless the parking Brake is set and the parking brake light is on. Well it seems that the parking brake light only comes on sometimes when I set the brake. Does anyone know where the sensor/switch is that makes this light come on? If the switch/sensor is bad I may just bypass it and put it on a manual switch to make the light come on.
Old Jan 15, 2012 | 10:04 AM
twags6's Avatar
twags6
The switch is located near the edge of the dash near the one rubber bumper for the parking brake pedal. Its a simple old school door switch that grounds out when you apply the brake. They usually corrode or rust, so cleaning it will help, or just bypassing it like you mentioned.
Old Jan 15, 2012 | 01:10 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Cleaning the contact usually does the trick. All you need is a 7mm nut driver and it comes right out. I use a little jewelers file to clean the washer and top of the blade contacts.
Chris Thiessen
Jun 15, 2019 09:44 AM
Bruin008
Jan 7, 2019 07:46 PM
Matthew Brown
1997 - 2003 F150
Aug 5, 2013 04:38 AM
razor_jim
Aerostar
Mar 24, 2004 02:16 PM
seattlecyclops
Sep 20, 2003 05:56 PM
