frame perch question
Old Jan 14, 2012 | 08:22 PM
MPshop's Avatar
MPshop
I bought a 76 2wd F100 with no motor/trans. truck originally came with a 390 FE and i have a 351W to go in the truck. What frame perches do i need to locate to be able to put the Windsor in the truck??
Old Jan 14, 2012 | 08:28 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Small block perches from a 2wd. You could use the I6/FE perches, but the engine will sit 1" higher.
Josh
Old Jan 14, 2012 | 08:39 PM
MPshop's Avatar
MPshop
Ok. Thanks!
Old Jan 14, 2012 | 08:48 PM
MPshop's Avatar
MPshop
Is there a company that sells them or is it time to hit the junkyard??
Old Jan 14, 2012 | 09:04 PM
Bullitt390's Avatar
Bullitt390
Junkyard bro... or post a WTB in the classifieds, someone might have pair laying around.
Josh
Old Jan 14, 2012 | 09:52 PM
fordman75's Avatar
fordman75
79 and older, 2wd 351M/400 perches will work too.
Old Jan 14, 2012 | 09:56 PM
Bullitt390's Avatar
Bullitt390
Positive about that? Those are 2 piece and different than the small block and I6/FE perches.
They won't work for an FE, can't see how they would work for a smallblock.
Josh
Old Jan 14, 2012 | 10:05 PM
fordman75's Avatar
fordman75
Here you go.
Comparison Photos of Engine Perches - FORDification.com
Old Jan 14, 2012 | 10:12 PM
Bullitt390's Avatar
Bullitt390
I've owned quite a few dentsides and have never seen a 2 piece engine frame perch/tower.
Here you go.
Hmmm... well 351/400 IS a smallblock.
I see it's the 429/460 that uses the 2 piece perch.
Josh
Old Jan 14, 2012 | 10:25 PM
fordman75's Avatar
fordman75
Josh
I haven't owned any dent side 429/460 powered trucks!
E30tdf
Engine Swaps
Nov 28, 2008 10:26 AM
kenz28
Oct 3, 2006 06:36 PM
pcmenten
22
Aug 24, 2004 07:20 AM
big_red_79
Jan 10, 2003 09:12 AM
