Found Rust Today
Old Jan 14, 2012 | 09:03 PM
Famousamos's Avatar
Famousamos
Found Rust Today
I began tearing out the carpet today and found what I expected, RUST
Looks like new floor pans are in my future. I searched several threads and just wanted to make sure I'm clear on replacing the floor pans. When I cut the old pans out, how much overlap do I need for the lap welds? Also do the floor pans come per-drilled for spot welds will I need to drill them myself! If so what spacing drill size?
Carpet Out
The PO laid down a thick coat of bondo/fiberglass on the driver side, what a mess
Old Jan 14, 2012 | 09:22 PM
HIO Silver's Avatar
HIO Silver
Welcome to corrosion central. I don't think Ford even used a toothpaste tube worth of seam sealer on these rigs.
You can either lap weld or butt weld. I prefer butt welding because I don;t have a flange roller or pneumatic flanging tool, plus it doesn't create a pocket joint where it can start corroding again.
Okay, you're lap welding.... Lay the cut out pieces on the new pans and trace around the silhouette. Then add the lap, about 3/4-inch is about right, to the trace. Floor pans do not come predrilled so either use a pneumatic punch, a hand punch, or a sharp 3/8-inch drill bit. Spacing should be about 2.5 inches on center, roughly about three fingers wide. Remember to use weld-thru primer and then seam seal both sides when completed. It wouldn't hurt to use POR-15 (or similar product) on the rest of the floors.
Old Jan 14, 2012 | 09:57 PM
Famousamos's Avatar
Famousamos
Thanks for the info, I'm not a good enough welder for a but weld, so I will be going with the lap weld. Also I plan on coating everything very heavy with undercoating once it's finished. Thanks again
Old Jan 14, 2012 | 10:46 PM
USArmyTaterness's Avatar
USArmyTaterness
If you haven't already make sure to ask your floor pan manufacturer the thickness of the steel some companies are passing off thinner less than adequate metal.
Old Jan 14, 2012 | 11:06 PM
ford1977owner's Avatar
ford1977owner
i heard that dennis carpenter replacement panels have a good thickness to them, just undercoat them with some type of rust prevention paint after you put them in
Old Jan 15, 2012 | 07:34 AM
grinnergetter's Avatar
grinnergetter
Use Weld Thru primer on the edges that you will clean up before you weld....and let it dry!!!!
Mrln45
Nov 9, 2018 03:57 PM
Treacy
Sep 3, 2015 10:41 AM
MAP53
Jun 23, 2015 07:50 AM
BaronVonAutomatc
1978 - 1996 Big Bronco
13
Dec 19, 2007 03:34 PM
codys50ford
Oct 1, 2007 10:40 AM
