Weird thump/clunking
Old Jan 15, 2012 | 09:10 PM
big-ugly's Avatar
big-ugly
Sounds u-joint related to me.. Going from drive to reverse and getting a "clunk" is usually a bad u-joint. Obviously there is some play in the system somewhere, now it's just a matter of finding where at.
Old Jan 15, 2012 | 09:14 PM
Midnite1987's Avatar
Midnite1987
I thought u joints too, that's why I changed them but the issue was still there.
Could te chain in the t-case be slack?
If I grab the rear tire with truck in park and roll it forward as back it seems to go more then I would think to be normal but when it stops at each theres a clunk that sounds to be comming from the middle of the truck. (kindof like the sound when changing gears but not as loud
Last edited by Midnite1987; Jan 15, 2012 at 09:15 PM. Reason: Stupid iPhone auto correct...
Old Jan 15, 2012 | 09:16 PM
big-ugly's Avatar
big-ugly
Hmm... good question... I haven't ever had to tear apart a transfercase, so I'm really not sure what the symptoms would be of a loose chain.. Hopefully someone else will jump in and give you some good solid info. I would think that would only affect being in 4x4, but I have no idea.
Old Jan 15, 2012 | 09:53 PM
deeznuts822's Avatar
deeznuts822
If you think its the chain in the case just unlock the hubs and see if it goes away.
Old Jan 15, 2012 | 11:30 PM
Midnite1987
After reading thumpers thread about his lowered truck pinion issues... His problem was the ubolts and the plate bending.... I'm wondering If I didn't tighten the ubolts correctly? The vibration started after doing the leafs.
What's the proper way to tighten them? And what torque?
I'll see if it goes away when I put the 3" blocks in the rear and get the new ubolts in. I don't plan on driving it till then anyways
Old Jan 16, 2012 | 03:47 PM
juni88126's Avatar
juni88126
Check the tranny mount, try unlocking the front hubs see if it stops.
Still Smoking
2004 - 2008 F150
Apr 9, 2015 02:32 PM
dogmantra
Jan 16, 2011 06:38 PM
tvsjr
2009 - 2014 F150
13
Dec 6, 2009 01:14 PM
30287f250
Sep 22, 2009 10:09 PM
aaronlockhart
Sep 17, 2007 04:53 AM
