Ok, so using the info I got from you guys today, I've determined that my fender solenoid is wired incorrectly for this starter.
Notice that the red wire on the top post, and the heavy gauge black wire both go to the starter. I'll have to move the black wire to the battery post when I go get new cables today. Not saying this was my problem, but it was a PO issue all the same. Fix one thing at a time, right?
I don't see anything major wrong with how that was wired. I'm guessing the small red wire on the starter side of the solenoid goes to the starter mounted solenoid.
Yes, the fender mounted unit is still carrying the load of the starter, but the heavy battery cable only has juice when the starter is engaged. Might cause the fender solenoid to need replaced a bit more often, but if the starter cable happens to ground itself to the engine or frame, it won't burn up the entire wiring system.......
The instructions that came with my starter were quite implicit not to tie the feed and trigger wires together.
(maybe back feeding is an issue?)
I ran my starter cable directly to the battery, figuring there was one less connection.
Not to mention a lack of room on the hot stud of the fender relay.
I just put wire loom on the cable like it came from the factory to avoid chafing.
Yea, I googled this wiring issue, and the most common way to wire this is to connect the heavy gauge wire directly to the battery post. I just got back from NAPA with my new cables...on my way out to rewire.
Now I need to run full tilt into the nearest oak tree, face first.
I swear I did my wiggle tests before I started buying parts. Turns out that the original issue was the eyelet end of the positive cable at the solenoid. The eyelet was crimped on, but not soldered. I guess you know the story from there....
So what I ended up with is a new starter, and new neg and pos SOLDERED cables. I also correctly wired the starter. I moved the large gauge cable to the new positive cable end at the battery post. As a side note, I LOVE that new starter! The old one rattled and buzzed, but this one is quiet and can propel the truck 35mph on it's own.
Glad you got rid of those worthless clamp on battery cable ends.
Nothing but trouble.
I had to change them out in my wife's Rodeo when the cold weather began.
Her starter cable is like 8' long and you have to disassemble the starter to get at the lug on that end.
Hopefully you will see years of good service from both the starter and the fender mounted solenoid now.
It seems, and it may just be wishful thinking, that the whole lighting system is much brighter. Interior, dash, and headlights really do seem to be much more brilliant...like I'm lit up like a Christmas tree.
Just me, or is that possible? Battery always seemed to have a great charge. If my lights are any indication, then I've had power problems for some time.
Not wishful thinking.
You had a crappy connection at both ends of your + cable.
Now everything is bright and tight.
I would suggest some Noalox on the ends of all the new cables though, to keep water and corrosion at bay in the long term.
The only thing those bolt on battery cable ends are good for is emergencies. It's good to have one if you are out in the field and need to repair the wire.
Other than that they are dreadful for corrosion problems and resistance issues.
I'd never use them for a permanent fix, too many problems...
Like I was saying the bolt on terminals are problems waiting to happen. When you compare the price of a clamp on terminal vs a new factory made cable it doesnt make sense to use the clamp ons. The clamps are like $2.99 and the new cable set you back a whoppin $7.00. Good deal the problems are over for now.
IDK, I've used them a lot mostly on Jeeps or off-road vehicles. When I have upgraded the cables to heavier cable I would use the soldier on eyes and then bolt it to the clamps. Never had any more problems that way than with the factory cable plug heavier cables.
