Sponsored by: Real Truck
Head Light options?
Old Jan 13, 2012 | 09:47 PM
clearwater1950's Avatar
clearwater1950
Talking Head Light options?
My 99 Super Duty has seen a lot of duty on gravel roads over the years. The head light lens are pitted, scratched dulled from sand blasting. They are so dim I run on High Beam....and I can still hardly see down the road on a dark night. Heaven help on a rainy night! It is like driving through a tunnel w/no lights on! The lights are so dim that other cars never flash lights to me know I am too bright. I checked on what it would cost for new head light assemblies and was astounded at the price....nearly $500 a set! Any one know of a place that sells lenses at reasonable prices?....or....anyone out there experimented with installing more expensive bulbs that are bright enough to overcome the poor light transmission through marred lenses? Help.
Old Jan 13, 2012 | 10:39 PM
JT301's Avatar
JT301
Check Ebay. You can get the set for around $100. Even upgrade to 05 headlights for less than $150.
Old Jan 13, 2012 | 11:52 PM
barthel's Avatar
barthel
1A Auto, Rock Auto, both have OEM style lights and good prices. (about $100 for the pair)
Old Jan 14, 2012 | 08:03 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
all the aftermarket heads are decent quality wise...just make sure to take some silicone around the casing edge and seal her up good.
pretty much every single aftermarket headlight has issues with leaking water. hence the silicone.
you should take this chance to do the 05+ head upgrade. same $$$ as replacing your current light
Old Jan 14, 2012 | 08:08 AM
deck60's Avatar
deck60
05 headlight
could all fo you talking about the 05 please tell more will the grille have to be changed and what about the wiring
Old Jan 14, 2012 | 11:41 AM
SCF250's Avatar
SCF250
Bump
Bump, I'm interested also. Would be nice if I could get it one piece at a time.
Old Jan 14, 2012 | 11:44 AM
Hotpocket's Avatar
Hotpocket
Old Jan 14, 2012 | 08:40 PM
charbaugh's Avatar
charbaugh
I have read in other threads that you can install the 05+ lights without changing the header or the grill. You will have to cut your header to accomodate the lights, though. I put in ebay after market lights in mine and had to cut the header also. No big deal.
Old Jan 18, 2012 | 09:19 PM
Ginther's Avatar
Ginther
I have an 04 too and was thinking about getting some 05up headlights. Does changing to the 05up headlights with the new style H13 bulb add any dangerous amp draw to the stock wiring?
I ask because I saw this heavy duty headlight harness at LMC Truck and was wondering if it's necessary?
I also read somewhere that there are two screws and clips you have to buy for the 05up lights that the 04 trucks dont have. Anyone have any input on that? Part numbers?
Thanks
Old Jan 19, 2012 | 05:18 PM
onebadv2's Avatar
onebadv2
I have an '03 F250 and want to change the headlights also. I do like the '05 style and have tried to find a "how to" but haven't found the one that makes me sure I can do it. Does anybody have the complete info? The ebay link said cutting of header but what about the grill? Thanks for all the help. This site is the first place I go to when I first get home and get online.
Old Jan 19, 2012 | 07:10 PM
The Metal Panda's Avatar
The Metal Panda
Use rubbing compound on your lenses to clear em up a bit.
HID kit.
Cheap and effective.
Old Jan 20, 2012 | 02:18 AM
carltonwebb's Avatar
carltonwebb
The grille will work. The header has to be enlarged to because the 05 hdlts are deeper for lack of a better description.
Old Jan 20, 2012 | 09:58 AM
Squirrel814's Avatar
Squirrel814
How difficult is it to get everything put in and cut out? I don't have much time or many tools at my disposal.
Streaky
Mar 24, 2014 03:21 AM
bearhugger
Oct 27, 2010 07:27 PM
weekendwarriorfsw32
Nov 13, 2009 01:05 AM
kittyhawk
Jan 26, 2005 08:23 PM
Dett
Dec 16, 2004 05:46 PM
