Hi all
Has anyone tried turning the factory rotors?I know that you arent suposed to with some composate rotors.Im not even shure what type my 01 f350 has.
I turned the ones on my 2000 F-250 4X4. The local brake places could not turn them due to the size. Even the local Ford dealer didn't have a machine large enough. I had to take them to a shop that does school buses, dump trucks. I don't think mine were any type of composite, just regular steel.
Just remember, if you are turning them because they are warped, they will warp even quicker the more they are turned. The heat tends to get to them quicker the thinner they get.
Just replaced my front rotors with the ART rotors...time will tell if it was worth the bucks!!!
The general opinion amongst my fellow gear heads is to replace them if you can afford it. People have been turning them for years but, nothing beats a new set.
My rotors dont seem to be warped at all and i have 35,000mi on them.I havent checked yet but im assuming that im close to needing new pads.Should i just slap on new pads,or should i still turn(or as monsta puts it )resurface the rotors?
Why bring them in a get them turned or what ever. As long as there is no pulse in the braking don't worry about it. If there is do the at home method, just through them old pads back on and drive around for a little while.
Your best bet is to have the rotors turned. When the rotors get hot and cool over the life of the pads, glazing of the rotor occurs. This glaze must be removed in order for the new pads to seat themselves properly. If you are to thrifty to take them in and be properly turned, You can use 80 grit sandpaper and carefully grind them yourself.
