Fuel Pump Problems!
Old Apr 9, 2021 | 08:50 PM
Ted928's Avatar
Ted928
My vehicle has recently developed a problem; often during cold start it will fire but die prior to a full start. I have to reengage the starter to get it it to fire and run. Maybe my FPDM is failing. How do I check? I have torque pro so I can read fuel rail relative pressure. What should it read when the key is on but prior to cranking? TIA
Old Apr 10, 2021 | 06:26 PM
steve(ill)'s Avatar
steve(ill)
dont jump in on a 6 year old post... Start your own.
The fuel rail should have 30 psi or so after it sets.. If you have a bad check valve, the fuel will run back into the tank and rail will have no pressure.. Then when you crank, you get a momentary start, then die.. Check the rail pressure to verify.. Turn the key ON ( 3 seconds)- OFF- ON ( 3 seconds) a couple times, but do not START.. Pump should build up pressure in the rail and start easier.. See how long it takes to bleed off.
Phase3
Dec 17, 2023 09:30 PM
FiznUKa
Apr 20, 2018 06:13 PM
jrutgersen
Dec 1, 2012 09:31 AM
mercman86
2004 - 2008 F150
Oct 2, 2011 04:24 PM
Talyn
Feb 10, 2009 05:50 PM
