Electrical problem...won't start
Old Jan 13, 2012 | 09:30 AM
brittans63's Avatar
brittans63
Hey everyone...I have a 2000 Excursion 7.3 4WD. Last evening, I stopped and when I went to take off the throttle would go down, but the truck remained on idle. I was only a couple of blocks away, so I "idled" home. When I turned off and tried to restart, only the BATTERY light and blinking THEFT light - no WAIT TO START, etc. Truck turns over just fine, will not start. New batteries. Any ideas? Thanks so much!
Old Jan 13, 2012 | 04:24 PM
JaySVX's Avatar
JaySVX
I'd check your fuel pump, make sure it's sending fuel. Engines need fuel, spark, and compression to run. Being diesel, you just need fuel and compression. Compression is less likely to be an issue on every cylinder, so I'd check fuel.
Old Jan 13, 2012 | 04:25 PM
JaySVX's Avatar
JaySVX
Generally you can check fuel pump by having someone put their head by it, and putting the truck in the on position, you can hear it going. If that's going, check fuel filters. Also a good time to check for oil in coolant and vice versa. Let me know how you end up after that.
Donald Heath
Mar 25, 2019 10:50 PM
white cat
1983 - 2012 Ranger & B-Series
Dec 16, 2013 10:33 AM
Rus01
Oct 23, 2010 05:41 PM
Orpackrat
Dec 27, 2009 08:23 PM
damnedin82
39
May 2, 2008 10:27 AM
