Gas Tank Conversion
Old Apr 10, 2012 | 11:06 PM
PapaBearYuma's Avatar
PapaBearYuma
My 79 F350 2wd has a narrow (34") frame, steel midship tank, and plastic rear tank. The rear tank is protected(?) by steel plates. FWIW
Old Apr 11, 2012 | 11:53 AM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Buck from what i understand the super camper specials with the 140" wb had a stock rear plastic tank. Atleast thats what chasetruck told me.
Old Apr 11, 2012 | 12:35 PM
Fordworth's Avatar
Fordworth
That's right. I currently have the plastic rear tank from the SCS that he parted out. It's not under the truck but I did mock it up and it does fit but requires moving a couple crossmembers around. My stock crosmembers even have the mounting holes for the straps already. Unfortunately, the fuel sender for that tank is unavailable. I modified one from an '84 Bronco II for it.
Old Apr 11, 2012 | 06:48 PM
bucks77ford's Avatar
bucks77ford
Yep, that is right. I did forget about the super camper specials stock tank that would fit the Highboys.
Old Apr 11, 2012 | 07:05 PM
crazyredneckanyhow
Picked up a bronco 2 tank yesterday. Looks like itll work out. My rear most crossmembers are shot so im havin some 3/16" plate bent into 2 new crossmembers. Just need to make some tank straps now.
Old Apr 11, 2012 | 07:08 PM
bucks77ford
Any of you guys have dual tank beds on your highboys and if so, are you making any sort of auxillary fuel tank?
JAYS 77 F-250
Feb 20, 2015 08:42 AM
gatoraid
Jan 13, 2007 05:22 AM
bucks77ford
Jun 18, 2006 12:38 AM
Ervin
Oct 20, 2004 11:16 PM
couleeman
1978 - 1996 Big Bronco
Mar 6, 2003 06:36 PM
