Glow plug how-to???
Old Jan 11, 2012 | 08:45 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Glow plug how-to???
Does anyone have a step-by-step on how to replace the glowplugs? Its for a 94 IDIT.
If not, could someone explain it to me? I have to help out a friend, and i know the idea, but not the details.
Old Jan 11, 2012 | 09:32 PM
Phy's Avatar
Phy
Assuming it's a factory turbo, first take of the air cleaner. The top comes off with 3 bolts, and a couple hose clamps. Under the air filter are 2 bolts to remove the air cleaner base. Then on each glow plug, pull the electrical connector and remove the plug. You'll need a 1/4" drive, 3/8" deep socket, ratchet, a U-joint, and several extensions. I get to the ones under the turbo by sliding the socket/U-joint/extension from the driver's side of the turbo, underneath it...
Search this forum for "stuck glow plug" and read what to do if you have trouble getting any out.
Good luck!
Old Jan 11, 2012 | 09:43 PM
Ford4Life7.3
Thanks! You didnt mention removing tve valvecovers, im assuming thats a 'duh', but how do i reinstall them? Just tourqe em down?
Old Jan 11, 2012 | 10:57 PM
Ford4Life7.3
Bumpedy bump?
Old Jan 11, 2012 | 11:14 PM
therifleman556's Avatar
therifleman556
you dont need to remove the valvecovers. theyre right there on top.
Old Jan 11, 2012 | 11:19 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Yep right on top next to the injectors.
Old Jan 12, 2012 | 12:01 AM
Ford4Life7.3
Gotcha, thanks! Like i said, on the PSD it's different. Luckily, (or unluckily, as it is now) i never had to change them on my 90' IDI.
Old Jan 12, 2012 | 07:53 AM
tjc transport's Avatar
tjc transport
i ain't rite
torque is very low, something like 10 or 12 inch pounds.
Old Jan 12, 2012 | 09:30 AM
Ford4Life7.3
So basically hand tighten and then a turn with the ratchet lol. Thanks again guys.
Old Jan 12, 2012 | 09:40 AM
tjc transport
i ain't rite
yup. i put them in snug with a 1/4 ratchet.
Old Jan 12, 2012 | 10:04 AM
Ford4Life7.3
Sorry for the dumb questions, but they just slide out right? Assuming he didnt use crappy ones that swelled?
Old Jan 12, 2012 | 11:05 AM
joshofalltrades's Avatar
joshofalltrades
the one set i removed were autolites which hadn't swelled yet, and some of them stuck to my socket as they came out, the others were simply lifted out with my fingers or a small pair of pliers. they're as easy as they can be
as you know, motorcraft plugs only, and put anti-sieze on the threads just in case you ever do change them again
Old Jan 13, 2012 | 07:45 AM
my1strealtruck's Avatar
my1strealtruck
After you change the glow plugs keep a close eye on your your return lines and caps. I changed my glow plugs and had had return line caps leaking. If you have not changed the return lines and caps I would do them at the same time.
Old Jan 13, 2012 | 11:01 AM
Ford4Life7.3
Will do, thanks guys. This is my buddies truck....highly neglected and never does maintenance. Im just doing the glow plugs lok
Old Jan 13, 2012 | 11:04 AM
Ford4Life7.3
Hes been using ether for nearly 5 months and has never taken the time to find out the problem, knows nothing about diesels, and doubt the fluids have been changed since old yellerwas a pup
akamacgyver
Feb 11, 2016 07:29 AM
Lexrocker
Jun 6, 2015 06:51 PM
kneisl99
Oct 20, 2011 05:09 AM
gumper 123
Feb 18, 2011 04:27 PM
ghunt
Oct 27, 2009 08:52 AM
