Cannot get transmission out
Old Jan 11, 2012 | 12:45 PM
rlpatte's Avatar
rlpatte
1997 ford ranger 4x4 3.0L 5-spd manual. Trying to replace clutch. Have transmission completely unbolted, sitting on a jack. We can't get it to back out of the opening between the firewall and the suspension cross member below (sorry, I don't know what it is called). The cross member ties to the front axle and has four bolts in the middle of it suggesting that it can be taken apart into two pieces. However, because of its association with the suspension I am reluctant to do that without knowing what the consequences are. The transmission bell housing simply will not fit between the firewall and this cross member. We have tried everything including tiliting it to the point where the transmission almost fell off the jack. Any help/advise would be greatly appreciated. I've never encounterd anything like this before and it has us at a complete standstill.
<!-- / message -->
Old Jan 11, 2012 | 06:55 PM
Phinxter's Avatar
Phinxter
I just read the removal procedure in alldata and it said to remove the crossmember.
Old Jan 12, 2012 | 10:27 AM
02FX45.4's Avatar
02FX45.4
Just pull the bolts out of the crossmember and pull it down.
bigcrunch
1997 - 2003 F150
Jul 8, 2016 09:29 PM
GeorgePBurdell
Jul 6, 2015 10:43 AM
phoglund
Bronco II
Jan 11, 2006 10:27 AM
Charger73400
May 8, 2005 08:26 PM
Charger73400
May 7, 2005 02:21 AM
