VIN help on early Econoline 5 window pickup
Old 12-25-2011, 12:08 AM
BlueOvalfan85's Avatar
BlueOvalfan85
BlueOvalfan85 is offline
Hello. I recently bought a 1961 Econoline 5 window pickup that I'm taking apart to restore. I need help decoding the VIN on it. Here it is: E10SH171672.
Also the wheel base is 090. Color is BM and the model is E103. The trans is A and the axle is 01. 3600 lbs GCWR and 74 HP @ 4000 rpms.
Thanks!
Old 12-25-2011, 12:22 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Also the wheel base is 090. Color is BM and the model is E103. The trans is A and the axle is 01. 3600 lbs GVWR and 74 HP @ 4000 rpms.
E10 = E100 Pickup.
S = 144 1V I-6.
H = Lorain OH Assembly Plant.
171672 = 1961, assembled May 1961.
90" Wheelbase.
BM: B = Turquoise / M = Corinthian White.
E103 = E100 Pickup, 3,600 lbs. GVWR
A = Ford 3 Speed Light Duty Manual Transmission.
01 = Ford 7 1/4" Rear Axle / 3.50-1 / 2,300 lb. Rear Axle Capacity.
3,600 lbs. Gross Vehicle Weight Rating.
74 net HP @ 4,000 RPM
Old 12-25-2011, 01:39 AM
BlueOvalfan85
Thanks, NumberDummy!
neveridle
15
02-07-2018 03:51 PM
Spaz1461
01-06-2018 01:04 PM
bleedbluetrucknut
Large Truck
04-13-2017 02:47 PM
Snowmanii
Large Truck
10-23-2016 11:17 AM
MarkB65
Large Truck
08-11-2016 09:44 AM
Quick Reply: VIN help on early Econoline 5 window pickup
