VIN help on early Econoline 5 window pickup
Hello. I recently bought a 1961 Econoline 5 window pickup that I'm taking apart to restore. I need help decoding the VIN on it. Here it is: E10SH171672.
Also the wheel base is 090. Color is BM and the model is E103. The trans is A and the axle is 01. 3600 lbs GCWR and 74 HP @ 4000 rpms. Thanks! |
Originally Posted by BlueOvalfan85
(Post 11195236)
Also the wheel base is 090. Color is BM and the model is E103. The trans is A and the axle is 01. 3600 lbs GVWR and 74 HP @ 4000 rpms. S = 144 1V I-6. H = Lorain OH Assembly Plant. 171672 = 1961, assembled May 1961. 90" Wheelbase. BM: B = Turquoise / M = Corinthian White. E103 = E100 Pickup, 3,600 lbs. GVWR A = Ford 3 Speed Light Duty Manual Transmission. 01 = Ford 7 1/4" Rear Axle / 3.50-1 / 2,300 lb. Rear Axle Capacity. 3,600 lbs. Gross Vehicle Weight Rating. 74 net HP @ 4,000 RPM |
Thanks, NumberDummy!
