4x4 not working
Old Jan 10, 2012 | 03:07 PM
jquick1's Avatar
jquick1
4x4 not working
03 v10 4x4 will not work in the auto lock,but will if you lock hubs. also will take a long time for the light(4x4) to go out. have only put it in 4x4 3times since 04. on has 72k miles. any clue? thanks
Old Jan 10, 2012 | 03:32 PM
LivingLarge's Avatar
LivingLarge
You may have a vacuum leak, or the hubs may need to be serviced (lubed) or replaced.
I live in florida, use my 4x4 about 1-2 weeks per year, but still pop it in 4wd every month and physically move hubs from auto to lock a few times.
A ton of Ex owners here have gone to manual hubs, but i prefer the oem's.
Old Jan 10, 2012 | 04:00 PM
VaSheriff's Avatar
VaSheriff
Just for the sport of it, rebuild them. It's very easy to do.
See these videos.....
Ford Super Duty Lubricating a 4wd locking hub Part 1 - YouTube
Ford Super Duty Lubricating a 4wd locking hub Part 2 - YouTube
Old Jan 10, 2012 | 04:24 PM
golfmedik's Avatar
golfmedik
Get some 3/16" rubber line(fuel hose, vacuum hose will do) and replace the lines following your front brake lines on each side. Those are your hub vacuum lines. Will take all of 3 minutes per side and see if that corrects your problem. Forgot how much you'll need but it shouldn't be over 3 feet per side.
Old Jan 10, 2012 | 04:25 PM
myblkex's Avatar
myblkex
Real good info - Thanks
Old Jan 10, 2012 | 09:48 PM
bobalonius's Avatar
bobalonius
My X ended up in the ditch next to my parents driveway Christmas morning last year and those 2 vac lines were the culprit. 4X4 light was on but the front hubs didn't lock in.
Old Jan 10, 2012 | 09:53 PM
EXv10's Avatar
EXv10
I leave mine locked at the hub all winter. I like the stock hubs but you can't always depend on them to be automatic.
Old Jan 11, 2012 | 12:18 AM
rikosintie's Avatar
rikosintie
I've said it once and I'll say it again, "Throw the PoS ESOF hubs away, put in MM or Warn Hubs and enjoy the rest of our life." Yeah you can clean and regrease them, replace the vacuum lines, put a vacuum gauge on the system, pull the hubs off and replace "THE" O'ring, blah, blah, blah.
I wasted hours and hours dicking with mine before I wised up and spent $100 on MM. Read the hundreds of posts on this site and then then think about how many thousands of hours have been wasted "trouble shooting" that system. And trouble shooting is probably the wrong term given how many things go wrong and leave them not working the next time you need them.
Now I just rotate to LOCK and I won't end up like Bobalonius did (I only got stuck several times before I figured it out).
Michael
Old Jan 11, 2012 | 03:28 AM
Daz00Excursion's Avatar
Daz00Excursion
My Backpack Gots Jets
Michael
coudlnt of said it any better myself.. its not that hard to jump out of ur EX to lock the hubs. i got MM in my EX and love em.
Old Jan 11, 2012 | 01:58 PM
jasonodsky's Avatar
jasonodsky
Once you get the issue fixed, make sure to exercise the hubs and 4wd on a regular schedule. Be it monthly, quarterly or each oil change. Run the system in a straight line or dry roads or on wet, rainy roads to avoid binding in the system while exercising it.
The long delay in dropping out of 4wd could be from the lubricant on the transfer case engagement motor and actuator getting old and gummed up by not using it frequently enough.
Old Jan 11, 2012 | 06:18 PM
EXv10's Avatar
EXv10
But you can just turn the dial.......what's the difference.?????
Old Jan 11, 2012 | 10:13 PM
white Buffalo's Avatar
white Buffalo
I did the same - got rid of the EOSF hubs and replaced them with Warn hubs from Riff Raff Diesel.........lifetime waranty
Here's the link:
Riffraff Diesel: Warn Premium Hub Set
af4ms
22
Jun 25, 2023 08:19 AM
TowsonX
Jan 11, 2014 10:25 PM
johntpr
Jan 5, 2014 03:39 PM
lcmains1
Jan 18, 2012 03:47 PM
99F350PS
Jan 4, 2005 12:18 AM
