Sometimes I'm not the smartest guy!
So next time when it won't turn over I'll check something simply like is it in park?
Next time I'd jiggle the shifter a little
at least i didnt have to walk as far to get in it when i got outa the toilet.
Similar thing happened to me with my 1978 Toyota Celica when in 1995 when I was a jr in high school. I couldn't get the damn thing to start one day after school. Walked-home, picked-up my mom's car to run my girlfriend to work, then my buddy and I went to go tow the car home with his Dad's Ranger. (The compact kind, not the dent-side kind.) When I shifted into Neutral for the tow home, realized it hadn't been in PARK. I let my buddy tow me home anyway, so he wouldn't know my dumb mistake. Told him later that it was the NSS. I've never told anyone this story until today.
The "click" is the solenoid working. If you hear a click, the problem is not the solenoid at all. I do not understand why this misconception has existed in people's minds since the beginning of time. Countless people on this site have wasted $20 on a new solenoid because of this exact advice.
When the solenoid clicks, you're hearing the sound of the giant slug inside slamming closed, connecting the battery to the starter through a circular plate. This is ALL the solenoid has to do. If the solenoid clicks yet the starter does not turn, something else is wrong. If the solenoid clicks and the starter turns yet the motor does not start then the starting system has nothing to do with the equation anymore because it's doing it's job.
When the solenoid chatters, this STILL does not implicate the solenoid. This means the working voltage of the battery is too low - either because of a low battery, bad battery, bad connections, or bad battery cables. The chatter happens because the battery voltage starts out high enough, so turning the key closes the solenoid - but as soon as the low-impedance starter is connected to the battery, the battery voltage is brought down low enough to let go of the solenoid. This disconnects the starter, which lets the battery voltage go back up, and since you're still holding on to the key, the solenoid closes again - over and over and over.
Folks, please digest this post and commit it to memory and stop wasting $20.
in an icy hospital parking lot! I almost ran over myself trying to run around and get in to stop it just before it would have hit a nice new conversion van.
luckily no one saw me
LOL THANKS.
1967/77 F100/350: The NSS (C7TZ-7A247-A) is steering column mounted, is operated by spring steel selector lever (DOTZ-7B097-B) that snaps onto the shift tube thru a hole in the mast jacket.
This lever has a knife bladed tip that fits into the NSS. The tip is notorious for snapping off, and the lever can lose tensile strength, causing it to fall off the shift tube.
When either occurres, the truck can be started in any gear.
1978/79 F100/350: The NSS's are transmission mounted. C6 (D8TZ-7A247-A) uses a different NSS than C4 (D8TZ-7A247-B).
