Sometimes I'm not the smartest guy!
Old Jan 10, 2012 | 07:12 PM
Skip1970's Avatar
Skip1970
snow man ice ice baby - YouTube
anyone like snowmen?
Old Jan 10, 2012 | 10:05 PM
wyckedcombo17's Avatar
wyckedcombo17
Hahhahahaha stop, collaborate and listen. Good one!
And ND, thanks for the clearing up on the NSS. My bad. FMC, thanks for clearing up the solenoid theories too!
Drac's Avatar
Drac
Save the old ones
Originally Posted by fmc400
Actually, it's the exact opposite.
The "click" is the solenoid working. If you hear a click, the problem is not the solenoid at all. I do not understand why this misconception has existed in people's minds since the beginning of time. Countless people on this site have wasted $20 on a new solenoid because of this exact advice.
When the solenoid clicks, you're hearing the sound of the giant slug inside slamming closed, connecting the battery to the starter through a circular plate. This is ALL the solenoid has to do. If the solenoid clicks yet the starter does not turn, something else is wrong. If the solenoid clicks and the starter turns yet the motor does not start then the starting system has nothing to do with the equation anymore because it's doing it's job.
When the solenoid chatters, this STILL does not implicate the solenoid. This means the working voltage of the battery is too low - either because of a low battery, bad battery, bad connections, or bad battery cables. The chatter happens because the battery voltage starts out high enough, so turning the key closes the solenoid - but as soon as the low-impedance starter is connected to the battery, the battery voltage is brought down low enough to let go of the solenoid. This disconnects the starter, which lets the battery voltage go back up, and since you're still holding on to the key, the solenoid closes again - over and over and over.
Folks, please digest this post and commit it to memory and stop wasting $20.
I aggree for the most part, Just let me add
Just because the Solinoid clicks does not mean it is always good.
Just like an Industrial magnetic contactor, the solinoid portion may work , but the contacts could be burnt. I have seen the contact disc and posts pretty burned up before.
You really need to use a meter to verify full voltage through the starter solinoid.
I only bring it up because I bin there
Old Jan 10, 2012 | 10:15 PM
buttwheat's Avatar
buttwheat
Since the OP didn't mention the year,
It is a '78 but it was not a NSS problem it worked fine it did it's job. The problem was the idiot(me) standing outside the truck bypassing the solenoid thinking it was bad.
Old Jan 10, 2012 | 10:36 PM
kyle1979ford's Avatar
kyle1979ford
whats NSS stand for? i have a problem with my truck coming out of park. one time i put it in park and got out and let it run (had to run to the house quick) then it popped into reverse and i ended up chasing my truck down the street. thankfully i caught it and it didnt hit anything. why does it do this?
Old Jan 10, 2012 | 10:43 PM
JB78f150's Avatar
JB78f150
neutral safety switch
Old Jan 11, 2012 | 02:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by kyle1979ford
I have a problem with my truck coming out of Park.
One time I put it in Park and got out and let it run (had to run to the house quick), then it popped into Reverse and I ended up chasing my truck down the street. Thankfully, I caught it and it didn't hit anything.
Why does it do this?
Bolted to the bottom of the upper steering column flange is a half moon shaped detent (*) aka shift gate. The tab on the shift lever fits in between the individual gates. \ P I R I N I D I 2 I 1 /
Peeps put the shift lever into Park before setting the hand brake, causing the truck to roll...just enough...that the parking pawl inside the trans locks up tight.
When this occurres, the shift lever has to be YANKED out of Park. Sooner or later, the gate between Park and Reverse snaps off.
So, when you place the shift lever into Park, it doesn't hold, drops into Reverse...not pleasant!
* 1978/79 F100/350 & Bronco: D8TZ-7A216-A .. Detent-Use without Tilt Wheel // D8TZ-7A216-B .. Detent-Use with Tilt Wheel.
Old Jan 11, 2012 | 08:15 AM
fmc400's Avatar
fmc400
MSEE
Agreed, good point. The solenoid could click but not actually pass current because of a burnt contact plate. It's definitely a good idea to make sure voltage shows up on the other side of the solenoid before replacing it - testing a part before changing it is something someone should always do anyway.
My main point was that it's very common for people to interpret the clicking sound as a sign of the solenoid being dead, when in fact the click lets you know that not only is power getting to the solenoid, but the slug is closing. The real time to suspect the solenoid is when you turn the key and you don't hear the click. If you then verify that you have 12 volts at the 'S' terminal with the key in START, the solenoid is bolted clean (grounded) to the fenderwell, and the solenoid still does not click, then it's time to replace it. Of course, if it clicks but does not actually apply voltage to the starter as you've said, then it should be replaced then too. However, 95% of people who replace a solenoid in my experience do not actually look for voltage anywhere and simply justify a "clicking sound" as a reason to replace it, without actually testing anything.
So, folks - keep Drac's point in mind in addition to what I said before.
Old Jan 11, 2012 | 10:51 AM
1977f250's Avatar
1977f250
One of my better moments was when I went to look at a 77 F150 4x4 short box. Pulled up to the guys house and there it was. Nice body, paint and a 4 speed was a must. He had got a huge overhead camper and needed a long box so wanted to sell the short box. He had the camper on jacks and had pulled the truck so the hood was just under the overhang. I looked it over and wanted to take it for a test drive. I jumped in and hit the key, it was in granny gear. It started almost instantly and lurched forward. I could have not come with in a inch of the windshield hitting the camper and I am sure it would have knocked it off the jacks. Well I had not pushed in the clutch and it was ready to go!!!!! I bought the truck and felt real lucky that I did not have to buy the camper also. One of my better moments.
flyjasfly
Feb 28, 2018 11:14 PM
fabchef
Sep 11, 2017 08:35 AM
nonickname13
Modular V8 (4.6L, 5.4L)
Nov 24, 2013 08:36 PM
59f100fixer
13
Dec 8, 2006 05:52 PM
orange peel
Apr 10, 2002 12:42 AM
