E40D question
Old Jan 8, 2012 | 05:11 PM
stang_crazy_gt's Avatar
stang_crazy_gt
E40D question
Im currently looking at a 95 F250 351/auto. The truck has 207k on it and no idea if the trans has ever had any work or been replaced.
Upon test driving i noticed any time you would put it to the floor it just would not kick down and go. So test it further I took it outside of town where there are some nice steep grades and when going up the hill it would not down shift n go. You could almost feel it hesitating or sorta jerking like it was fighting its self to get up the hill but would do so even on flat surfaces.
In town driving and normal pace everything shifts fine etc.... going down the highway without putting it to the floor it shift fine.
I know these trannys are known for issues but just wondering if the symptoms are familiar? There is no flashing OD light and no CE lights illuminated.
Im just wondering if its more than likely the trans or if its possable its another issue somewhat related. This isnt pushed me away from still wanting the truck as I have no problems doing the work and even putting a trans in if need be.
Thanks Mike
Old Jan 8, 2012 | 05:16 PM
86F150302's Avatar
86F150302
Pull codes. Even if there isnt a check engine light there can still be codes.
Is it slamming into gears also? There is alot of info on E4OD issues on here. Just gotta search.
Old Jan 8, 2012 | 05:19 PM
stang_crazy_gt
no it shifts into gears nice n smooth even the occasional time it does down shift and go. yeah I may have to to see about another test drive and scan it. Then again since I actually like the truck enough and the price is pretty fair i may take my chances and expect the worse case scenario that itll need a trans.
Old Jan 10, 2012 | 05:48 PM
jeffkayers's Avatar
jeffkayers
Just to me...it sounds more like a communication problem in the electronics. I doubt a tranny swap would be needed. The right troubleshooting may lead to an easy fix.
Old Jan 10, 2012 | 07:24 PM
danr1's Avatar
danr1
No forced downshifts,
1- Check fluid level - high or low
2- Check electronic engine control operation
3- Inspect valve body bolts - bolts loose or tight
4- Inspect valve body - Dirty or sticky valves
Give ya an idea what it could be and what it might take to correct it.
Old Jan 11, 2012 | 07:22 PM
stang_crazy_gt
I was able to scan it tonight and the codes I got were
172, 116, 636, 114, 111
All codes were KOEO and the truck was cold.
I did take it out tonight on an open road and took off from a dead stop and put the pedal to the floor and it climbed it RPMs and finally shifted and it did shift a little hard. Then after it shifted you could feel the jerking it was doing while accelerating.
Mike
Old Jan 12, 2012 | 03:08 PM
Weberman3's Avatar
Weberman3
With my AOD in my F150 it has about 110,000 miles on it since the last time it got rebuilt but for it to shift some times (down or up) I have to treat it like a manual (I guess shes gettin a bit worn). My E4OD in my F250 started doing some of the same things you said. I wish I could help more but I put in a ZF in the 250 instead of messin with the E4.
Old Jan 12, 2012 | 03:48 PM
Encho's Avatar
Encho
The Southernmost Mod
Before you start testing things like a headless chicken check the throttle cable, if it's messed up the tranny won't react fast enough.
Old Jan 12, 2012 | 06:51 PM
stang_crazy_gt
Yeah im a check that and I have a good feeling it needs a T/P sensor as ive noticed the last few days of driving it depending on where the pedal it it starts bucking and doing some of the other sypmtoms ive described.
Ive just not had time to really look at it. So I get the cable checked and T/P changed out ill report the outcome.
OldBlack4x4
Jan 9, 2015 04:43 PM
clarkbre
Sep 4, 2014 07:37 AM
relentlessmx
Dec 20, 2008 02:14 PM
MOERULES
Jun 27, 2008 07:47 AM
RLKBOB
Nov 6, 2004 10:29 AM
