I thought your Ex is at stock height right now, why is it your ball sit kind off low according to the picture. How many inches above the ground does the ball have to be?
I run mine basically at 'full rise':
When I'm not towing, I leave the "L" bar on and just remove the ball hitch section (pull the two pins closest to the bumper).
Found the wire from the rear of the truck, the schematic show a BK/PK wire as the backup lights, found that too after prying out the protective cover; it was so brittle so that will need to be cover again after the attachment.
So I need to attach the after market light hot wire to this and find a place to ground the backup light wire, correct?
Thanks.
Originally Posted by robert_l_ross
When you tie in, make sure you use the hot wire and not the ground. If you use the ground and the bulb burns out in the factory reverse light, the aux light won't work since the bulb breaks the circuit when burnt out.
I ended up tying my backup cam into the harness at the bulb. It was a little more time, but I didn't have the schematic and didn't really want to tear apart the harness and probe to find the right lead. Hardest part was getting the wire through the giant rubber grommet behind the tail light housing. I used a large Phillips screwdriver to 'stretch' out the opening long enough to get the wire through.
The rear lights I have tied to a switch alone. At some point I'll modify the switch to an on-off-on and add some diodes to let me choose to have them come on 'auto' with the reverse signal or 'manual' with the switch or 'off' completely.
Thanks.
Well not exactly VQT. You need a relay. Here is a simple wiring diagram. Basically you need to run a hot wire and ground to the relay. Hook the aftermarket light wire to the relay as well as the factory backup wire. The diode will protect the factory wire. You then can run another wire to either a switch or simply a key on hot wire/fuse tap. If you go that route then tie into the reverse indicator so they will turn on when in reverse. Otherwise a 3 pole switch so you can turn on when you want. Hope that helps some.
I am not sure what will happen if you tap the hot wire into the factory reverse then ground it. It may work but the aftermarket lights might not get enough power since that is a pretty small gauge wire. Do you have the wiring diagram or link for the lights you bought. That would help us a lot.
I am still in a research stage on the lights. Then I will need to buy the whole combination of lights and relay together so it won't be any confusion for me later
I think your diagram is a bit off...you need two diodes - the way it's drawn you could backfeed into the switch circuit.
I think this would be safer:
The only problem with this layout is that you never have an 'off' option - they always come on with reverse lights. I didn't choose this method because on our trailers we have big shiny rock guards and the trailers are white. At night, the combination of factory reverse lights and the bigger aftermarket ones made quite the glare to deal with through the rear window. I liked to have the option to turn them on manually, on auto (the diagram shows both options), but also to not have them come on at all.
At the local PepBoys around here, Pilot sells a kit of the switch, relay, and wiring without lights.
Personally, I wouldn't go for the kit, I'd get a single relay, switch and a roll of wire - it would probably be cheaper and the wire will come in handy for other projects. If you go with diodes to get them to tie in to the factory or to give you then on-off-on option, Radio Shack will have them for cheap. You will want to get a soldering pen or one of those 'cold-solder' devices (they run off of AA batteries) that don't have a heat up time and is cold to the touch when you are done soldering.
Good eye, you are right a diode would protect the switch better. I didn't think to include one since it was a grounded and fused switch, but that isn't a perfect failsafe like a diode. Better safe than sorry. I probably would not use the backup light signal at all and just make the lights activate by a switched source as needed at night instead of every time you backup day or night as you mentioned.
I'm actually going to eventually do the three wire setup on mine. I need to find a Carling three way first. I'm hoping it's not too big of a deal to pull one of the ones from the Riffraff 650 kit. Maybe just add an 'auto/manual' additional switch if its too difficult.
Thats probably what I will do too. If I can do it with the Riffraff kit I will just add a 3 pole to the dash next to the high idle switch somewhere near the headlight switch.
In my Expy I did a tiny 3 pole on the front side of the overhead console...don't think I'll do that on the Ex since I may put a gauge pod up there...
