Sponsored by: Real Truck
Using auto tow
Old Jan 7, 2012 | 09:59 PM
Andy350's Avatar
Andy350
Using auto tow
We test drove two 2006 5.4 350 Super Duty's today. How do you know when you turn on the auto tow that it's working? In my 1999 I have now, the RPM increases when I turn it on. We didn't notice any RPM change when turning on/off the auto tow. Also drove a 2006 V10 and with that we saw the RPM change.
Old Jan 7, 2012 | 10:05 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Do you mean tow/haul? Your '99 doesn't have a tow/haul mode. All it has is a button that turns off the overdrive gear.
In tow/haul the transmission upshifts at a higher speed than normal. It also downshifts much more aggressively and has engine braking. This is more noticeable with a load.
Old Jan 7, 2012 | 10:19 PM
Andy350's Avatar
Andy350
Yes, you are right, I mean the tow/haul. It's the button you push at the end of the automatic shift handle. Just confused though, why was it obvious when the button was pushed on the V10, and not at all noticable on either of the 5.4liters. The lights came on the dash so it looked like they were both activated. Thanks
Old Jan 7, 2012 | 10:27 PM
galaxie641's Avatar
galaxie641
DO about 70mph and slam on the brakes and you'll know it when it downshifts.
Old Jan 8, 2012 | 01:35 PM
spud57's Avatar
spud57
If the obvious difference was a change in RPMs then you probably switched to Tow/Haul at a different speed. Tow/Haul changes the speed in which the transmision shifts into OD and it also changes the torque converter lock-up. Could have been either one.
All things being equal, there should be no difference between the V8 or V10.
S
Old Jan 8, 2012 | 02:34 PM
Mark Kovalsky
There will be speed differences between the V8 and V10 when they shift. The torque curves are different so the shift schedules are different. If the trucks have different axle ratios that will change the speeds, too.
EdInArk
Large Truck
Feb 27, 2017 08:23 PM
Heavy Duty f250
May 30, 2011 11:09 AM
OnTheTrail
May 16, 2007 08:29 PM
fordmudduk
Jan 22, 2006 02:22 PM
cpd806
Sep 14, 2005 01:52 AM
